Rod length? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 09-16-2006, 11:28 AM   #1 (permalink)
Does anyone know the connecting rod length of the 955i engines?
What is the piston pin offset distance?
Thanks for your time.
[ This message was edited by: Devious2XS on 2006-09-16 13:16 ]
Reinstated
Devious2XS is offline   Reply With Quote
Old 09-16-2006, 02:27 PM   #2 (permalink)
Favourite Bike: Today - MV Agusta F4 312
fivehundo's Avatar
Other Motorcycle: 2002 955i Daytona CE
Extra Motorcycle: 2009 Tiger 1050
You building a Daytona from scratch? :-D
I'll parooze through the manual but I couldn't tell you off hand.
"The Father wove the skein of your life a long time ago. Go and hide in a hole if you wish, but you won't live one instant longer. Your fate is fixed. Fear profits a man nothing." Herger the Joyous
fivehundo is offline   Reply With Quote
Old 09-16-2006, 03:17 PM   #3 (permalink)
Just making mods to a 1050 engine and comparing to a 955i.
Rod length - 160mm
pin offset - 1mm
Reinstated
Old 09-16-2006, 06:33 PM   #4 (permalink)
fivehundo's Avatar
Trying to shorten the stroke or something?
Sounds cool! I'm interested...
Old 09-17-2006, 09:13 AM   #5 (permalink)
I'm using engine wave modeling software to compare the 955i and 1050i engines, and to look at what is possible for more performance.
Once accurate numbers are input, the software allows for modeling intake and exhaust lengths, taper, air box volume, etc, as well as camshaft alterations from stock cam timing changes to custom cam duration, lift, profiles, and ramp rates.
I can alter just about any engine perameter and the modeling software will accurately show what the changes accomplish.
Reinstated
Old 09-20-2006, 08:42 PM   #6 (permalink)
SWEEEEEET! :-D
sshbsn is offline   Reply With Quote
Tried a SE V-Rod The Rocket Science Forum 63 07-08-2007 01:40 AM
Raced a V-Rod HooliganRandy Triumph SuperSports 7 05-30-2007 09:43 PM
more on thrown rod eldo Twins Technical Talk 13 09-23-2006 02:21 PM
Anyone else thrown a rod? eldo Twins Technical Talk 11 09-14-2006 04:44 PM
V-Rod SoccerRef The Rocket Science Forum 9 02-13-2006 12:38 PM
