You will find a little black, phillips head screw on either side of the inner (black) headlamp assembly. Its right inside the cockpit where the upper meets the infills. Each screw will have a +/- sign above each screw. Basically, each screw corrects the headlamps left to right alignment.
HTH,
Ski
