Motorcycle.comAdvanstarMotorcycleShowsBikeBanditTrident-Exhausts.com
ShopTriumph.com
Old 07-10-2004   #1 (permalink)
Favorite Bike: 98 T595
Other Motorcycle: Polaris Preditor 500
Has anyone tried to put a 200/50ZR/17 tire on a daytona? just woundering if the 200 is that much bigger than the 190's. Looks like some pretty good deals on e-bay for them is all.
Photo Album
You can't stop it you can only Hope to Contain it!!!!!!
nyolds is offline   Reply With Quote
Old 07-10-2004   #2 (permalink)
not sure about 200's, but if you drop down to 180's, you'll be able to take a turn better. save money as well.
Old 07-14-2004   #3 (permalink)
Thanks for the info. There's not to many good curves here in Kansas but they would be the right choice for Missouri.
Photo Album
Old 07-14-2004   #4 (permalink)
Favorite Bike: Daytona Super III
Hinckley's Avatar
Other Motorcycle: Suzuki GT750
Extra Motorcycle: CB900F FOR SALE!
I have not taken the time to really study this so do some measuring before purchasing your 200.
Your bike comes with a 6" rear wheel, a 200 should spoon on to your rim without much excitement. Where you may run into trouble with clearance to the swingarm. Take a close look at your rear wheel at it's widest part, normally where the tread and sidewall come together. Measure the distance from the tire to the swingarm, chain, splash guard, etc. Look for anything that is within 20mm from the edge of the tire. Depending on the manufacturer of the tire you choose, the width of the 200 will only be 10mm wider than the 190 (actual width will vary slightly from manufacturer to manufacturer). You need to be sure there will be a little "wiggle" room after the 200 is installed, I'd say no less than 10mm from any given obstruction.
Of course increasing your tire width is going to slow your handling. But, you talk as though that is not much of an issue for you.
Take some careful measurements and do what you need to do. I hope this helps. :-D
UFOB #56
"An armed society is a polite society. Manners are good when one may have to back up his acts with his life."- Robert A. Heinlein
Hinckley is offline   Reply With Quote
Old 07-14-2004   #5 (permalink)
Hinckley's Avatar
[ This message was edited by: Hinckley on 2004-07-14 06:18 ]
UFOB #56
Old 07-15-2004   #6 (permalink)
Thanks for the lowdown Hinckley. I think a 180 does sound better after all.
Photo Album
Old 07-18-2004   #7 (permalink)
I put on that exact tire size, forget it! too much tire wear in all the wrong places. Unless you go wider ont he front you aren't using the whole tire. Stick with a 190
Later
Tire size question AVM Tiger Chat 3 08-02-2007 09:34 PM
Tire size question? POPPE Twins Technical Talk 1 06-19-2007 07:35 PM
tire size for 69 Bonnie Classic, Vintage & Veteran 1 11-13-2004 04:20 PM
Replacemnt tire size????? Trophy 3 03-19-2004 06:15 PM
Tire size Modifications & Workshop Talk 0 05-09-2002 01:25 PM
