Old 09-02-2006   #1 (permalink)
Favorite Bike: 01 ducati m750 dark
Other Motorcycle: 99 triumph daytona 955i
the thermostat helps regulate the internal coolant temp- keeps it stabilized for efficient operation of the engine and the control systems. operating outside the design paradigms can cause a number of problems, usually expensive. on fuel injection systems - mixture is a function of engine coolant temperature. too rich (cold- open loop, i.e., choke on) and wash out oil film in cylinder and contaminate lube oil - too lean (numerous causes), hot operation, high combustion chamber temps- internal engine damage. take yer pick and pay yer cash, mates. i say test an no-stat-condition on your own machine, if you feel confident- if it works out all right, cool- if not, live and learn. also, periodic coolant changes are good- no matter what coolant you use. don't believe the hype about long life coolants (especially dexcool), it all deteriorates over time and use. it is cheap insurance to replace it every year or two, compared to corrosion damage repairs. that being said, this is one reason i like my air-cooled ducati (don't get me started on 'oil' stuff). but, *****, that triumph just screams so nice...
two wheels, a motor and yer ass
motorcritter is offline   Reply With Quote
T100. Good Points v Bad Points. UK Daveski Twins Technical Talk 13 08-15-2007 05:59 AM
Nology Clarification BadMouth Hinckley Classic Triples 6 06-14-2007 08:16 AM
Tire clarification II Flylow Sprint Forum 15 03-26-2007 07:25 PM
Tire Clarification RickyT Sprint Forum 19 01-29-2007 02:11 AM
Bafflectomy Clarification pbr2424 Twins Talk 2 07-26-2006 08:30 PM
