Trident-Exhausts.comAdvanstarMotorcycleShowsBikeBanditMotorcycle.com
BikeBandit
Old 06-15-2004   #1 (permalink)
http://www.thunderbike.co.nz/workshop/faq/#Q-6.1
i was the bloke who kept whining on about my daytona 1200 had no go below 3500rpm,discovered this site and learnt that you can also shim youre carb needles up a notch or 2 to richen up the bottom end, if air screw alone isnt enough,my needles wernt dynojet so there wernt any notches,so a quick visit to my nuts and bolts tin produced 4 identicle close fitting washers "1mm thicknes MAYBE A BIT LESS. took the the plastic shim off the needle on with the washer,back on with the shim put needle back in slide reapeat 4 times.The result ."ONE HAPPY BUNNY"The old girl pulls strong from as low as 1500rpm,there is a lot of usfull info on that site ,well worth a look, :razz:
Fully sorted T140 V Bonneville. For sale !! Bonnevillet140v Classic, Vintage & Veteran 0 10-07-2007 06:23 PM
Got the Scrambler sorted. Wow, what a difference. JBarn3 Twins Technical Talk 2 07-18-2007 02:41 PM
I think I'm getting the suspension sorted out - Long ohiorider Twins Technical Talk 10 08-13-2006 09:41 PM
"Well sorted" ironduke Classic, Vintage & Veteran 8 03-10-2006 01:11 PM
getting sorted (new bike and new bee) edfrank Modifications & Workshop Talk 2 06-04-2002 12:53 PM
