02 Daytona 955i headlight high beam issue? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 06-27-2006, 12:12 PM   #1 (permalink)
Keefer
Hello-when I switch to high beam my right side headlight goes out-when on low beam they both work-I've checked the bulb on the right and that is not the problem,the bulb is good(right side when sitting on the bike)Anyone know why it might be doing this?Any help greatly appreciated.
Old 06-27-2006, 12:21 PM   #2 (permalink)
Moderator
Favourite Bike: 04 Daytona 955i
TechmanBD's Avatar
Other Motorcycle: 07 Victory Kingpin
Hi Keefer,
Just to be 100% sure, did you swap the bulbs to see if the problem follows the bulb? If it stays on the right side, there could be a relay that is bad on the contacts that goto the right side. I am just guessing that there is a relay from basic mechanics knowledge because I haven't worked on my bike. It is new and have the extended warranty so if there is a problem, I just let them deal with it :-D
Off topic. Welcome to the site. I see you live in Glendora. My friends and I go out there all the time to ride on Sunday mornings. Best time when it isn't crowded. Haven't though in a couple months though. Too many things happening, getting married, honeymoon stuff like that.
Live as if you were to die tomorrow. Learn as if you were to live forever. - Gandhi
TechmanBD is offline   Reply With Quote
Old 06-28-2006, 12:15 AM   #3 (permalink)
wow.... mine does the same thing it might be my bulb though. I havnt checked interested to see what you find out though
2002 Daytona
SS brake Lines
1 down in the front 2 up in the rear
Carbon rear hugger
CCC Exhaust
http://i38.photobucket.com/albums/e1...6/DSC00159.jpg
Japawhat02 is offline   Reply With Quote
Old 06-28-2006, 12:29 AM   #4 (permalink)
Favourite Bike: 2004 Red Daytona
Other Motorcycle: 1996 Super III Daytona
Extra Motorcycle: 1999 Red Daytona
japawhat02.... if that is your bike in the picture...the silver one, did you install the flush front blinkers? i have the same... i want ya to check this for me on your front and rear blinkers...check to see if you have the black wire that is from the bike to the blinker, is it hooked to the solid black on the aftermarket blinker? check all 4 aftermarket blinkers and make sure that the factory black wire makes to the aftermarket blackwire...i had the same problem because i got in a hurry one evening and i figured that a dc bulb wouldn't matter if i wired it backwards....the blinkers worked but i noticed on the ride at night that the headlights had a problem...i would have to check the wiring diagram but it appears to me that they might be switching both wires thru a relay... anyway i got home and changed the next day and the problem disappeared...
so Keefer....do you have aftermarket blinkers installed?....if so check out the 4 blinkers too....
CHECK OUT MY BLOG...www.triumph-travels.blogspot.com
I've got 2 words for ya.."Shake and Bake"...oh yeah that blew you mind didn't it????.
dano is offline   Reply With Quote
Old 06-28-2006, 09:55 PM   #5 (permalink)
thanks dano ill check them tomorrow sometime and ill let ya know of it worked, but like i said i havnt even checks the bulb yet
2002 Daytona
SS brake Lines
Carbon rear hugger
CCC Exhaust
High Beam/Main Beam whatever headlight - ***!!!!!!! tuk Sprint Forum 24 11-18-2011 03:17 PM
:::low beam & high beam on a '06 Sprint??::: hANNAbONE Sprint Forum 25 12-10-2009 04:06 PM
High Beam Adjustment rjb340 Speed Triple Forum 0 10-05-2007 12:19 AM
high mount exhaust for 05 daytona 955i??? bobbyphat Maintenance & Workshop Talk 2 08-31-2006 09:10 PM
Daytona 955i Headlight Switch Fault Daytona Deliberations 0 05-23-2004 04:53 PM
