Brooksie, There are two bolts, one each side that will have to be removed. They are on the underside of the upper triple clamp and at each handlebar.
Which ever method you use, the front will have to come off the ground or you'll most likely have trouble getting the center bolt on the upper triple clamp aligned. A rear paddock stand is also highly recommended.
Brad
