On 2006-06-26 06:59, lesterg wrote:
I tried the idle suggestions to see whether it would reset the ECU, but no luck.
Went to the Triumph dealership and they checked the mapping, the mapping was not recommended for any Triumph. They downloaded the recommended Triumph mapping and she is now running smooth.
One can only wonder who and why, right? Glad you got it fixed! When I first read your post, it sounded as though you might have a vacuum leak, though those will usually cause the idle fluctuate a up and down a bit (or a lot).
[ This message was edited by: kilroy914 on 2006-06-27 18:35 ]
