Wolf Underseat - Triumph Forum: Triumph Rat Motorcycle Forums
Honda Powersports SportbikeTrackGearMotorcycle.com
Old 06-15-2006, 07:41 PM   #1 (permalink)
As many of you know, I ordered a wolf underseat for my 955i daytona practically the day I bought it. I've posted a couple of weeks ago about the poor fit. Well, Peter changed pipe suppliers and sent me a set of the new ones. I am not the kind of guy who refuses to reverse his position so here I am....doing exactly that.
The new pipes fit...well....PERFECTLY. I mean the bends are spot on, the canisters now fit beautifully AND there are clamps to seal them to the Y pipe. Seriously a beautiful exhaust. I did have one difficulty in that the lower pipe, where it fits over the stock header...was loose. No problem, I thought..the clamp will pull it tight. But it didn't. I modified the clamp so that it could squeeze tighter but it then stripped the bolt of the clamp. Being a fabrication kind of guy, I used a grade 8 bolt and nut..drilled out the nut on the stock clamp and cranked that baby down TIGHT. No leak now. Oh, I also had to cut a relief in the lower pipe so that it could be tightened down.
In this pic you can see just above the bolt head that the relief slot as delivered is squeezed to the point of touching and at the bottom of the joint there is still a gap.
I widened both of the slots with a cut off wheel, then made two more (like the stock pipe) and now she fits wonderfully. Here is a pic of the widened slot.
Here is a pic of the grade 8 bolt fix.
I consider the lower joint to be a minor thing, and am very happy with the new bends and fit. I am working on getting to a dyno with the stock system so I can run them both back to back (new bends fit so well I can just remove the wolf as a whole, slide on stock and replace...in minutes. I'll post a full review after that, including dyno charts etc. All in all, MUCH happier with the wolf system now. Thanks Peter.
Bill
[ This message was edited by: billindenver on 2006-06-15 17:42 ]
billindenver is offline   Reply With Quote
Old 06-15-2006, 08:00 PM   #2 (permalink)
I just took a look at the pipe that was originally delivered with the system and here is a pic of the slot it came with. The new pipe's slot is a third that size at most. About the thickness of a bandsaw blade actually. Other than that Peter...these new pipes are PERFECT and as I said, widening the slot was 30 seconds work. Had I done that before I stripped the stock bolt...it really would have been no problem.
If I were British I would describe the new pipes as some part of a dogs anatomy, or perhaps an insects knees or something...but as a Yank...I'll just say....they fit far better than George Bush as president.
Bill
Old 06-15-2006, 08:07 PM   #3 (permalink)
Oh, and take a look at the welds in that third pic... Beautiful.
Bill
Old 06-16-2006, 03:12 AM   #4 (permalink)
Senior Member - Site Sponsor
Favourite Bike: 1968 Bonneville T120
Wolf's Avatar
Bill - thanks for the heads up on the slots - all are being widened today
Regards
Peter Sorrell
Trident Exhausts
www.trident-exhausts.com
Triumph Only Exhaust Specialists
Wolf is offline   Reply With Quote
Old 06-16-2006, 08:53 AM   #5 (permalink)
Favourite Bike: '04 D955i
bradtx's Avatar
Other Motorcycle: '98 T595
Bill, I had a feeling that all was going to be made right.
Did you see my e-mail about the air filter?
Brad
Old 06-16-2006, 09:50 AM   #6 (permalink)
No sir, didn't get that. Yahoo's spam filter sometimes gets over enthusiastic though, so it probably was flushed by them. You can shoot it again, and I'll watch the spam folder just in case.
Off to the mountains on the bike today. :razz:
Bill
Old 06-16-2006, 04:19 PM   #7 (permalink)
awesome, I knew peter would make it right, he has excellent service. Bill, how about some big pics of the whole exhaust on the bike. Here is my high level.
\'05 daytona 955
rino2301 is offline   Reply With Quote
Old 06-26-2006, 03:48 PM   #8 (permalink)
How does this thing sound? Is it loud? Lets see some pics! :hammer:
" 60% of the time...it works EVERYTIME."
955iLimited is offline   Reply With Quote
Wolf Underseat Issues ocgeorge Sprint Forum 5 05-29-2007 04:37 PM
Wolf underseat: *NOISY!* Am I doing something wrong? loco Daytona Deliberations 8 01-30-2007 06:30 PM
Wolf underseat exhaust ST harley1942 Sprint Forum 7 09-27-2005 08:23 AM
wolf underseat exhaust for st on ebay JulesSmith Sprint Forum 0 06-03-2004 08:24 AM
References on Wolf underseat exhaust? Speedyswede Sprint Forum 0 04-07-2004 05:30 AM
