Adjusting rear shock - Triumph Forum: Triumph Rat Motorcycle Forums
Old 06-12-2006, 10:31 AM   #1 (permalink)
I just purchased an '02 955i which is presently owned by someone over 6' tall. He had the rear shock adjusted to, I assume, "raise" the height and set it up better for him. In getting the bike better set up for me, under 5' 6", is adjusting the shock just a matter of turning the preload with a tool provided in the bike's tool kit? Easy to do when I pick the bike up?
Thanks!
stellasue is offline   Reply With Quote
Old 06-12-2006, 02:00 PM   #2 (permalink)
Im pretty sure that is what the dealer did for me when I got mine, Im 5'6" and it works for me now. I think it eventually lowered about 1/2 inch.
\'05 daytona 955
rino2301 is offline   Reply With Quote
Old 06-12-2006, 04:41 PM   #3 (permalink)
Favourite Bike: '04 D955i
bradtx's Avatar
Other Motorcycle: '98 T595
stellasue, Welcome to the forum. :-)
Check out this article..
SportRider lowering info
..it'll give you a better idea of what's involved.
Brad
Old 06-12-2006, 10:47 PM   #4 (permalink)
Hi stellasue,
Based on the fact that you asked the question and i am guessing a woman, you are likley significantly lighter than the the 6 foot guy you are buying the bike from. Translation: you can and should take some of the spring preload out of that bike. this will drop the effective saddle height for you when you are on the bike. the good thing is the 02 tona has a pretty stiff rear spring, which means you can dial out a lot of preload, and get some drop in the rear ride height. try to keep things even though (or make them even if the last owner didn't by dropping the front preload as well to keep chassis attitude correct.
Long answer short, you will need a spanner and some patience to loosen the two collars that are used for adjusting the spring preload. this is not a five minute job and i would not recommned doing it at the time of purchasing a bike from a private party. suspension adjustments should be done when there is time and patience and a pen and paper handy to record your changes.
nyctester is offline   Reply With Quote
Old 06-13-2006, 07:14 AM   #5 (permalink)
Favourite Bike: 2012 Daytona 900
Brooksie's Avatar
Other Motorcycle: 2008 Kawasaki ZX14
Great article Brad. Thanks!
Brooksie is offline   Reply With Quote
Old 06-13-2006, 09:06 AM   #6 (permalink)
Thanks for all the great info. I'm glad there's a forum for Triumphs instead of just a mailing list, like my last bike. Such a vast amount of knowledge and experience to share, and you guys are such a help.
Ends up we'll have to trailer it home anyway :cry: so I'll just adjust it or have it adjusted here.
stellasue
[ This message was edited by: stellasue on 2006-06-13 07:11 ]
Old 06-23-2006, 10:20 AM   #7 (permalink)
BillyKinz
Depending on your weight you might need to make other adjustments to compression and rebound damping. For an excellent article from Motorcycle News go to: http://t955i.net/default.aspx?tabindex=55&tabid=55
You won't regret buying a Daytona!
Old 06-23-2006, 12:51 PM   #8 (permalink)
Favourite Bike: 03' Triumph Daytona 955i
Other Motorcycle: GSXR 600 (Track Bike)
Extra Motorcycle: Taking donations...
Alright, can someone please translate the "King's English" into American for me????
I am 6 ft 1 and weight 220.....exactly how many "stones" am I??? :-D :-D :-D
Track Days at Gateway International Raceway- 2008 Visit WWW.MCRARACING.COM
Looking for a good M/C web forum in St. Louis? WWW.GATEWAYROCKERS.COM
Skiandclimb is offline   Reply With Quote
Old 06-23-2006, 05:21 PM   #9 (permalink)
bradtx's Avatar
Ski, 15.71 stone. Check this site out..
conversions
Brad
Adjusting The Rear Wheel operators1 Trophy 13 07-13-2008 04:14 PM
Adjusting pre-load on the rear shock Tee-Dub Speed Triple Forum 10 07-20-2006 12:24 PM
adjusting the rear springs on a t100 CaptSeadog Twins Technical Talk 3 07-05-2006 10:10 AM
adjusting rear suspension moschika Twins Talk 2 07-31-2005 06:16 PM
adjusting rear brake lever punisher Triumph SuperSports 6 03-01-2005 07:29 PM
