what is the purpose of the position light - Triumph Forum: Triumph Rat Motorcycle Forums
Old 06-11-2006, 05:25 PM   #1 (permalink)
Ok i am stumped... does anyone know what the position light does or is used for ? it is the little light between the twin headlight beams on my 2002 daytona. i a, sure you guys have this silly little thing as well but the question in my brain is WHY???
nyctester is offline   Reply With Quote
Old 06-11-2006, 06:52 PM   #2 (permalink)
Favourite Bike: 2004 Red Daytona
Other Motorcycle: 1996 Super III Daytona
Extra Motorcycle: 1999 Red Daytona
i heard that it was a "parking light" when you turn off the bike...then turn the handlebar full left then turn the key to the lock position, there is one "click" left past the lock position. the bike will be locked and everything off except the little light up front and one in the rear brake light. i heard that you do this to signify that you are going into somewhere but will be out shortly. that way the bike is locked but has an indicator that you will return shortly. thats what i have been told ....all my Triumphs have had this feature....
CHECK OUT MY BLOG...www.triumph-travels.blogspot.com
I've got 2 words for ya.."Shake and Bake"...oh yeah that blew you mind didn't it????.
dano is offline   Reply With Quote
Old 06-11-2006, 10:20 PM   #3 (permalink)
i agree
king4456 is offline   Reply With Quote
Old 06-11-2006, 10:59 PM   #4 (permalink)
Cool thanks. You have confirmed that this bulb is useless to me. Now all I need to do is figure why electric fans stay on after you turn the bike off... How much hotter is any part of the bike going to get when combustion is no longer taking place. I rewired that problem out of my last bike, but i would bet doing so on the tona would cause a fault code to trigger...
Old 06-12-2006, 02:42 AM   #5 (permalink)
what would be the purpose of rewiring the fan? it doesn't run for that long after the bike is off so why would you?...its not gunna drain the battery as little as it runs...
Old 06-12-2006, 10:19 AM   #6 (permalink)
the position light is supposed to tell the veiwer which way the bike is positioned, like on a boat, to tell what direction it is going. i think that describes it the best
pyrodave is offline   Reply With Quote
Old 06-12-2006, 10:29 AM   #7 (permalink)
Favourite Bike: '04 D955i
bradtx's Avatar
Other Motorcycle: '98 T595
nyctester, Coolant is still circulating for a short time after the engine is turned off...the hot coolant in the engine displaces the cooler (by comparison) coolant in the radiator. The after running of the fan equalizes coolant temperature. It's a good thing.
As for the position light? I haven't had many bikes (I just keep my good choices a long time) the only street bike without some form of position lighting had a four way flasher.
Brad
Old 06-12-2006, 06:56 PM   #8 (permalink)
silvoor's Avatar
I believe the parking light is or was required in the U.K.
Never drink alone.
Never ride in a pack.
Always buy a drink for the woman wearing fishnet stockings.
silvoor is offline   Reply With Quote
Old 06-12-2006, 07:23 PM   #9 (permalink)
It has been referred to as a "City Light". In Europe, when they pull into a pedestrian area where the street lights are bright, the head lights were to be turned off not to be a hazard for the pedestrians. They have a different light control switch on the European models. By law in the US you have to have the headlight on. This was explained to me by a friend from Liverpool.
Keep the shiny side up and the rubber down.
cal-riss is offline   Reply With Quote
What is the purpose of these icons? ggRAT Site Happenings and Discussions 2 12-05-2007 04:21 PM
Joining RAT (Purpose?) TrOjAnUK RAT - United Kingdom 21 09-12-2007 11:12 AM
bulb recommendations and position light PtboSprintSt Sprint Forum 15 04-23-2007 11:11 AM
Modding cyclops or position light jonross Sprint Forum 6 07-16-2006 07:44 PM
Position Light Bulb biker1059 The Rocket Science Forum 5 02-18-2006 09:24 AM
