Runar
Take a look at the members photo section and Fatjim's folder. You will see my Daytona 12 before and after the removal of the fairing and stuff.
The parts used are :-
Thunderbird sport.... top yoke, clock mount, throttle cable, choke cable and hydraulic lines.
Speed Triple mark 1.... clocks.
Tiger mark 1.... handlebar clamps (with the vibration rubbers shortened to fit) and speedometer cable.
Speed triple mark 2.... headlamps and mounting bracket.
Other stuff.... aftermarket indicators mounted on brackets from top radiator mount. A home made bracket to fit the headlamp bracket to the Daytona 12 frame (where the old fairing bracket used to mount. The horns are mounted on a home made bracket on the left hand side of the engine (same place as the Thunderbirds), and finally a home made "chin" guard to protect the oil cooler hoses at the front. Don't forget to leave the bottom fairing mount framwork on. This mounts the oil cooler.
Hope this helps. Good luck.
FatJim :-D
