B1lly, Keep track of which items were removed from where and here we go:
1. Remove the side covers and seat, disconnect battery.
2. Remove the hoses on the left side of the tank.
3. Remove the two bolts holding the tank.
4. Remove the two hoses on the right side of the tank by depressing the tang and pulling the connector out. Tank may weep at this point, have a rag handy.
5. Disconnect the two electrical connectors.
6. Lift tank out.
7. Disconnect electrical connector atop airbox.
8. Remove hoses (extra in front if secondary air injection).
9. Remove fittings at rear of air box and lift off.
10. Remove the coils.
11. Blow out the sparkplug's recess with compressed air.
12. Set plugs to .7mm/.027"
13. Install plugs and reverse the above.
If I've forgotten anything, someone will chime in. :-D
Now's a good time to replace the air filter. If you feel the need to replace the fuel filter, it's under the plate on the right side of the tank.
Brad
