Old 05-11-2006   #1 (permalink)
snakepassweasel
I just got my '04 955i (about 5k miles) back from a dealer service, and theres a noticeable whine which I think is coming from the front wheel at about 40mph. Above this speed the noise gets a higher pitch and is lost in the engine/wind noise. It seems entirely related to road speed.
I've never noticed it before.
It's not engine or gearbox related as it still happens in neutral with the clutch in and doesnt change with engine revs or gearbox engagement.
It doesn't seem brake related, brakes on/off makes no difference. I can't sense any additional rolling resistance.
The plan is to get it back to the dealer ASAP but I'd be interested if anyone out there had come across this before?
I'm thinking wheel bearing but it's odd it started straight after the service and surely the WB should last more than 5k?
SPW
Old 05-11-2006   #2 (permalink)
Favorite Bike: Today - MV Agusta F4 312
fivehundo's Avatar
Other Motorcycle: Triumph Daytona CE
Extra Motorcycle: Husqvarna SMR 450
Interesting.... :???:
Here's a long shot but: make sure the tire is mounted with the correct rotation direction. There should be an arrow on the side or something. I had a similar problem with a car tire on my M3.
If not that...uh...Faulty Bearing? :???: Maybe???
"The Father wove the skein of your life a long time ago. Go and hide in a hole if you wish, but you won't live one instant longer. Your fate is fixed. Fear profits a man nothing." Herger the Joyous
fivehundo is offline   Reply With Quote
Old 05-11-2006   #3 (permalink)
Favorite Bike: '04 D955i
bradtx's Avatar
Other Motorcycle: '98 T595
Extra Motorcycle: '03 RC51, sometimes
SPW, One thing I can think of is the speed-o-meter's drive on the left side of the front wheel. Possibly damaged when your bike was placed on stands? Anything rubbing?
Brad
Old 05-11-2006   #4 (permalink)
Favorite Bike: Daytona 955i 2004 Se
Nickwiz's Avatar
Other Motorcycle: 1200 Daytona 1995
Extra Motorcycle: BSA Starfire 1968
I'd go for speedo drive too. My old S3 used to whine if you tightened the threaded collar that held the cable into the speedometer, too tight.
it takes a better rider to ride an old slow bike fast than a new fast bike slow!
Old albums: http://www.triumphrat.net/photogalle...m792/album634/
New albums: http://www.triumphrat.net/memberalbums/useralbums.php
Nickwiz is online now   Reply With Quote
Old 05-12-2006   #5 (permalink)
snakepassweasel
Thanks for responses!
It isn't the tyre and there's nothing obvious rubbing.
The speedo drive sounds most likely - the noise does somewhat resemble a dentists drill which would make sense.
Nickwiz (or anyone else) have you a torque setting for the collar, and did you have to replace washer/seal/ anything else after your overtightening episode?
SPW
Old 05-12-2006   #6 (permalink)
bradtx's Avatar
SPW, I think Nick is referring to a cable that turns within a housing...Am I correct? The sensor on the '04 D955i is electro-mechanical with two wires running out of it, up the left fork leg, then to a connector under the nose fairing. It wouldn't take the shop 10 mins. to try another drive.
Brad
Old 05-12-2006   #7 (permalink)
Dad_Roman's Avatar
The way he describes it , I swear somethin is rubbin on the tire.
Ride Safe!
Dad_Roman
"RexDad"
Dad_Roman is offline   Reply With Quote
Old 05-12-2006   #8 (permalink)
bradtx's Avatar
Oh Dad_, you've done it now. NZ is totally seperate from AU and they like it that way. Kind of like you or I being called an Okie (no offense Mad, you'd feel the same in reverse.)
SPW, For the record I back the All Blacks first and then ANYBODY playing against Australia. :razz:
Brad
Old 05-12-2006   #9 (permalink)
Nickwiz's Avatar
Yeah the old T3 series S3 had a cable. I didn't use a torque setting I just backed the collar off until the whine stopped. The collar is on the instrument housing by the way not at the drive on the wheel.
Old 05-12-2006   #10 (permalink)
Dad_Roman's Avatar
Brad
Jesus brad, ya put this in the wrong thread, your reffering to <60 .
You must be havin a GREAT Friday night! :nana:
Stand by, I'm on the way!
[ This message was edited by: Dad_Roman on 2006-05-12 19:51 ]
Ride Safe!
Dad_Roman
"RexDad"
Whining Pom Dylan Sprint Forum 4 02-01-2007 05:46 AM
Whining noise (the bike, not me) snakepassweasel Modifications & Workshop Talk 2 07-17-2006 05:05 AM
loud whining noise after shut bike down in hot weather PtboSprintSt Sprint Forum 4 06-22-2006 06:19 PM
Whining noise Nic900 Speed Triple Forum 10 07-26-2005 06:28 PM
Now my wife's whining! What seat? Ron_S The Rocket Science Forum 18 07-26-2005 11:20 AM
