I think what you're calling a damper housing the fiche is calling a "tube, inner assembly" and if that's right then I'll need the VIN number off your bike.
the crown cap... is that the dust seal? or is that the cap at the very top of the fork?
dust seal ... 2040080-T0301
top of fork cap... 2040071-T301
preload o-ring... 2040074-T0301
I've printed the pages with these part numbers, do you have a fax number I could send them to. I don't think they would scan (for email) very well because the numbers are so small.
hope this helps, let me know about the VIN.
daytonacharlie
[ This message was edited by: daytonacharlie on 2006-05-08 21:39 ]
I ended up just ordering a #26 set from the fiche (had the dealer fax it finally ...) as well as the #25 o-ring and the #18 washers. My RECENTLY-OLD dealer just ordered me a couple pieces from the kit and 2 pairs of oil seals. I will just eat the cost on the parts I already ordered I guess.
Oh yeah, part #11 -- the damper rod -- was $333.79 ... I am looking for a set of used forks instead.
