Old 04-25-2006   #1 (permalink)
in my dealings with the Triumph dealer's parts counter, it appears that there is a difference between 1999 955i Daytona models with the last 6 numbers in their VIN and 71698 below and 71699 and above. the problem is, that the parts guy doesn't know what the differences are.
does anyone know what these differences are? i have not run into a parts compatibility issue yet, but would love to avoid one. i have seen that the two VINs use a different fuel filter assembly plate gasket for the gas tank.
i had a '72 Triumph T120 (Bonneville) and ran into the same issue with different parts for the same model.
"dogs are cool because, you know, if they could, they would weld." - vulbus
vulbus is offline   Reply With Quote
Old 04-27-2006   #2 (permalink)
The only things i've found on my late build 99 that didn't come on the earlier 99's, are the 1 piece shifter and stiffer spring on the rear shock. I didn't get the (down) up-graded ecm unit, though. I got the older MC2000 unit.
Cheers, Lee S.
Keeper of the Schwartz
lee955i is offline   Reply With Quote
1999 Daytona 955i Dayton955i Daytona Deliberations 11 10-06-2007 04:53 PM
Differences between the Daytona & the Sprint 955i? WickedSick Daytona Deliberations 7 08-24-2007 02:45 PM
daytona 955i/speed triple 955i luggage differences? LOWEY Daytona Deliberations 0 01-01-2007 01:47 PM
I am looking for a 1999 Daytona 955i motor. Daytreim Daytona Deliberations 0 04-10-2006 03:05 PM
1999 Daytona 955i Daytreim Daytona Deliberations 0 04-10-2006 02:54 PM
