Hi,
I'm wondering if anyone can assist with this problem. when I have the lights on the battery is only being charged at 12.35 volts at around 2500-3000 rpm. As soon as the light are off I'm getting 13.8-13.9 volts steady at idle. resting voltage for the battery is 12.6 volts. I did a sort of load test on it, cranked the engine over and measured 9.0 volts at the terminals. I have stripped and cleaned all plugs/connectors on the bike. Cleaned the ground point on the engine. No change. Can anyone tell me what is causing this or any other checks that I need to do to narrow it down, cause it's sending me nuts. Any help or advice appreciated.
:hammer:
