> Or, just take it to the dealer and have them look at it.
This is really the best advice.
I mean, stress_reliever wrote: "every time i try to give it throttle it just seems to bogg down it will finally wake up but then it time to shift." This is not a description of a bike that merely hasn't been tweaked enough or had enough aftermarket goodies glued onto it--it's just pure-D not normal for that engine, period!
Let them run a diagnostic on it to make sure there's not an air leak or a serious throttle body imbalance, make sure the sensors are working correctly (if it's not the throttle bodies, I'd almost bet on a sensor), let them refresh the EFI map if they think that has anything to do with it (it could, if you were not running the stock exhaust system, for instance), and thereby be sure everything is mechanically and electronically up to snuff before you go dinking around with band-aid "fixes."
You can't cure pneumonia with Nyquil. No matter how much of it you drink.
[ This message was edited by: Diego on 2006-03-11 19:21 ]
John
