need a bit of advice to help cut back on time stood in the pouring rain switching my yokes!!!
got my speed triple yokes (last piece of jigsaw in doing the conversion!!!)
however as i said, its now pouring with rain- surprise- and i dont have a garage. so had a quick go at planning the switch, but have come up head scratching.
removed the front wheel and slackened all pinch bolts on yokes and bars, removed the top steering stem nut and dropped the forkes clear of the top yoke.
yoke is still on with no signs of budging, is it the head bearing adjuster nuts still locking it in place?
i'm probably being a 'spanner' but i can't see how these would anchor the yoke in place. i'm also tired and wet, so its probably glaringly obvious fatigue n' all.....but any help would be apreciated.
i was hoping to get away with not having to tamper with the head bearing nuts, as this also means filing out about 2mm from the mountain bike spanner i had to make it fit.
i take it is possible to remove the top yoke, but leave bottom yoke and steering stem in place...?
WHICH BRINGS ME TO PART 2!!!!
have been unofficially advised that sticking a speed trip top yoke on to a daytona steering stem and bottom yoke can't happen.
had a good look at the components, and i'm hard pushed to see why not.
anyone know any different?!
cheers for all the ongoing help, hints, advice etc!!!!
