help Daytona 1200 forks - Triumph Forum: Triumph Rat Motorcycle Forums
Old 03-04-2006, 07:25 AM   #1 (permalink)
dean68uk
Hi All just trying to dismantle my front forks and I am stuck trying to remove the damper rod. I have the triumph tool for this but when I try to release the lower holding bolt, the damper cartridge unscrews instead leaving the bolt below firmly in place connected to the lower part of the damper rod. I have read the other threads, but i am really stuck will my cartridge be damaged and how can I get the whole cartridge out? Thanks dean
Old 03-04-2006, 08:12 AM   #2 (permalink)
Favourite Bike: 2007 Thruxton Bonneville
Other Motorcycle: BSA Starfire 1968
Extra Motorcycle: 1930 Triumph NSD.
I haven't had my forks apaert so I can't help there.
Anyone else?
Nickwiz is offline   Reply With Quote
Old 03-04-2006, 11:12 PM   #3 (permalink)
Favourite Bike: 1996 Daytona 1200
daytonacharlie's Avatar
Dean,
I did the same thing you're doing, got stuck at that same point and ended up taking it to a suspension shop (Computrac) who specialize in Racetec suspension kits and let them finish the job. The problem for me was not having the special tools needed to go further. I'm not completely sure about the procedure but I believe there are two tools required to remove the cartridge. If you only have one of them then that might be the problem, sorry I couldn't be of more help.
dc
daytonacharlie is offline   Reply With Quote
ZRX1100/1200 forks jefftarlton Sprint Forum 5 03-10-2007 02:44 AM
1200 Daytona vs. 1200 Trophy? ElJugador Triumph, Models & Dealers 1 07-13-2006 01:25 PM
Daytona forks for Sprint RS? RSRAT Sprint Forum 4 09-10-2005 07:33 AM
Daytona 955 i forks Daytona Deliberations 0 05-04-2004 04:23 PM
USD Forks on daytona 1200 dietDrThunder Daytona Deliberations 22 01-14-2004 06:39 AM
