Hi All,
Well, following NVBOOZEFIGHTER's lead I installed a 17T counter sprocket on the '04 this afternoon. The sprocket is from Sprocket Specialists, p/n 598-17.
It took me about three hours 'cause I had to go get a 36mm socket and undo the rear sprocket to get enough slack to pull out the c/s sprocket. I lubed the c/s sprocket with some high temp grease before buttoning everything up.
How's it work? What's the difference? Well, the bike feels lighter...if that can make any sense! A half throttle quick shift from first to second lifted the front tire briefly...it didn't do that before. It's only ~5% taller, but seems to suit the torque curve (plateau) quite nicely. Bike's not buzzy at cruising speed, but I'm going to have to re-tune my ear to keep from trying to upshift out of sixth.
Brad
