Better Light - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearMotorcycle.com Classifieds!Honda PowersportsNew Bonneville
Old 02-18-2006, 03:36 PM   #1 (permalink)
silvoor's Avatar
I replaced the stock headlight bulbs with the "new and improved" bulbs of the same wattage but "50% brighter".
They do put out a brighter beam.
I bought Phillips but all the big names make them.
Never drink alone.
Never ride in a pack.
Always buy a drink for the woman wearing fishnet stockings.
silvoor is offline   Reply With Quote
Old 02-18-2006, 04:23 PM   #2 (permalink)
Mad
These are the brightest bulbs I have found so far. I have them on the Daytona, the S3, and the Hayabusa. I have tried them all and these Xenon blue kryptons are absolutly the brightest bulb available.
Mad`
Xenon Blue Krypton Bulbs
Mad is offline   Reply With Quote
Old 02-19-2006, 04:31 PM   #3 (permalink)
Favourite Bike: 2002 RS
Stlakid's Avatar
Other Motorcycle: 1981 Honda CB-900F/w full Greer Fairing (#0001!)
You don't want to use ANY coated Blue bulb as it's all hype! The blue coating filters out the light to 'Look' brighter thats all. And the term filter should be a clue....you WILL lose usable light. The ONLY way for these bulbs to get brighter is to up the wattage to overcome the blue filter which can and does overheat the stock Triumph wiring. There are some quality 'Blue Glass' bulbs available but the effects are the same, just maybe not as severe. Those are NOT them. My bet is if you look it will say 'Made in Korea' on those in which case they aren't worth buying.
The +50 White bulbs that Silvoor bought are the best you can do with the stock wiring on these bikes and they are a good upgrade. Just buy a reputable brand such as Osram Silverstar (not Sylvania) GE Mega Light or the Power Bulbs House branded stuff. (which are GE bulbs re-boxed) They are having a buy one set get a set free right now as well. Killer deal! Free marker lites and free shipping world wide as well. I got my Osram's in four days from them. (before the special sale of their brand)
Power Bulbs
My Photo Album
Stlakid is offline   Reply With Quote
Old 02-19-2006, 07:09 PM   #4 (permalink)
Mad
Power Bulbs
Your right man. That's why Mercedes and Porsche use them. Good call, you are the man.
Mad`
Old 02-19-2006, 09:10 PM   #5 (permalink)
Mad`
Merc and Porche use actual HID bulbs(plasma light), not incandescent bulbs with blue filters.
check your facts.
An intelligent man is sometimes forced to be drunk to spend time with his friends.
--Ernest Hemingway
Cerberus is offline   Reply With Quote
Old 02-20-2006, 04:11 AM   #6 (permalink)
Stlakid's Avatar
Cerb, just so you know there is a Fret here, you just met him. :thump:
My Photo Album
Old 02-20-2006, 05:59 PM   #7 (permalink)
thanks for the heads up.
--Ernest Hemingway
Old 02-21-2006, 08:11 PM   #8 (permalink)
Favourite Bike: 1996 Daytona 1200
daytonacharlie's Avatar
I've been using 55/100 watt H4 bulbs in my '96 D12 for 8 years now with no wiring problems at all. There's something special about having 200 watts of retina melting high beam power on a mountain road at night. I know they're allegedly for off road use but I'm always quick to dim them when on coming traffic appears. There's no replacement for wattage displacement.
daytonacharlie is offline   Reply With Quote
Old 02-22-2006, 05:33 AM   #9 (permalink)
Stlakid's Avatar
I used the same bulb in my 900F Honda. I even stepped up to the 90/130 bulb. (single headlight) I also had no problems with either setup. I don't know what wire gage they used in 1996, but I do know that Triumph is known to have 'Over Engineered' the earlier models and possibly that included the wire gage they used for the headlight. I'm pretty sure the light housing is probably bigger on your model (less heat) as compared to the newer 'molded in' look of the newer bikes. So for you and the earlier models it may be just fine, but most of the newer stuff and definitely on the RS I have the wire gage is at least one size to small for the standard bulbs. They look to be 14 gage and most would recommend a minimum of a 12 gage wire for a 120 watt (10 amp) load. I just feel better if I'm giving out advise to error to the safe side.
If the wiring would handle it and the sockets or maybe even the housing wouldn't melt from the heat I would be using the 55/100's on my RS for the very reasons you like them, I just don't feel like doing a rewire or ad a relay to the setup with better sockets for the short time I will probably have the high beams on.
Being that it would probably be short time use it may be OK as you have found, I just don't feel comfortable telling people it WILL be OK unless I'm very sure, and the parts used in the late model stuff just doesn't inspire confidence for a higher load.
My Photo Album
Old 02-22-2006, 11:24 AM   #10 (permalink)
Stlakid you are correct to err on the side of caution especially when it concerns electrics. I agree with your assessment that the earlier T3's were over engineered (and over weight) and I'm sure that's why I've had no problems with my setup.
silvoor, what model Triumph do you ride?
NB FEK installed, brake light works no running light pbcurran Club Cafe' 9 10-25-2007 03:20 PM
Integrated Tail light, brake light and turn signals?? stinger Sprint Forum 15 04-03-2007 10:21 PM
Intermittent Fault - Engine warning light & Fuel light Tassie_Tiger Tiger Chat 4 06-13-2006 09:58 AM
Engine light and erattic low fuel warning light guy71 Daytona Deliberations 12 04-17-2006 09:18 AM
fuel light or fool light? welshrob Sprint Forum 8 10-06-2005 12:57 PM
