Oil drain plug stripped on sump, leaking oil - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 26 (permalink) Old 02-01-2013, 10:20 AM Thread Starter
onisf's Avatar
Is this normal? The damn drain plug started to strip the threading on the pan so now i'm leakin oil after i finally got it on. I ordered a pan right away just now on Ebay, im just worried the drain plug might do it again in the future. Im going to be selling it soon and i dont want to give prospect buyers any excuse to lowball lol!
Sent from my SGH-T959V using Motorcycle.com Free App
SAVE US TIME AND USE THE SEARCH FEATURE
onisf is offline
post #2 of 26 (permalink) Old 02-01-2013, 10:30 AM
Main Motorcycle: 08 Street Triple
Lasermax's Avatar
Other Motorcycle: 2007 Speedmaster
Re: Oil drain plug stripped on sump, leaking oil
They make larger, self tapping drain plugs for that very problem, as well.
Lasermax is offline
post #3 of 26 (permalink) Old 02-01-2013, 10:40 AM
Main Motorcycle: Kawasaki W800
Other Motorcycle: 1972 Suzuki Hustler
The main cause of sump plugs stripping the threads out is simple. Overtightening. Find out what the factory torque value is, and use a good torque wrench. Use a new crush washer as well.
M.G.Vig is offline
post #4 of 26 (permalink) Old 02-01-2013, 10:54 AM Thread Starter
onisf's Avatar
Aw man, oh well I always wanted extra t595 oil pan in the garage.
onisf is offline
post #5 of 26 (permalink) Old 02-01-2013, 10:57 AM Thread Starter
onisf's Avatar
It was on there pretty good. Would you know if that crush washer would be available at a local auto store. Id rather go 2 blocks then 10 miles to the dealership.
onisf is offline
post #6 of 26 (permalink) Old 02-01-2013, 11:21 AM
DEcosse's Avatar
I would not personally use a larger sump bolt but repair with a helicoil (or timesert or your other favourite thread insert device) - it is M14 x 1.5 thread.
The easiest kit to use is the PermCoil Perma-plug system - everything you need in the kit, including a special 'stepped' tap, that threads into the original thread as a leader & cuts the new coil thread.
That means no drilling required! Plus a winder tool to insert the coil.
This is the M14 x 1.25 thread kit, but shows how the tap works
This is about the cheapest I've seen - http://www.woodys-auto-supply.com/au...d=THK-3221M14F
If you are searching, look for PermaCoil 3221 M14F
You need a 14mm size crush washer - absolutely available at just about any autoparts store.
Torque spec is 25Nm
You will need a new gasket to replace the sump pan - it does go by engine serial number so you will need correct one.
It can be replaced with the engine in position - you will need to remove the headers.
When you get a moment please add your bike info (year/model) to your profile.
DEcosse is offline
post #7 of 26 (permalink) Old 02-01-2013, 11:23 AM
I can't say whether the auto stores sell a washer for your Triumph, but they do a wide range. I found one that fits my BM and it was only 90 pence!
M.G.Vig is offline
post #8 of 26 (permalink) Old 02-01-2013, 11:31 AM
As DEcosse has rightly stated, a helicoil insert is the way to go. In fact, the fix is better than new! Any good machine shop can help you, failing which you can buy DIY helicoil kits online in the UK/US.
DeanRider is offline
post #9 of 26 (permalink) Old 02-01-2013, 12:28 PM
Main Motorcycle: Daytona 955i -04
+1 for helicoil! Used them on few bikes. Works well
Sent from Motorcycle.com Free App
Henkka83 is offline
post #10 of 26 (permalink) Old 02-01-2013, 12:50 PM
Main Motorcycle: Triumph
defo a thread repair such as helicoil.
I've never seen a self tapping sump plug....... that's a horrible idea.
rupert fridge is offline
Advice on a stripped sump plug/threads crazypierre1 Classic, Vintage & Veteran 6 03-23-2012 08:48 PM
Thruxton Stripped Sump Plug Voltaire Air Cooled Twins Technical Talk 17 08-12-2011 02:27 AM
Sump drain plug SilentUnicorn Classic, Vintage & Veteran 11 01-20-2011 05:00 AM
stripped sump plug thread roo010 Thunderbird Twin - Technical Talk 8 10-06-2010 12:55 PM
Stripped Drain Plug...Is it sae or whitworth? Joeydirty Classic, Vintage & Veteran 0 05-17-2009 12:16 PM
