valve shims & Buckets - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 36 (permalink) Old 01-19-2013, 07:57 AM Thread Starter
Main Motorcycle: '04 Daytona
tri955i's Avatar
Other Motorcycle: 1990 Kawi Ninja
I've searched the forum on valve adjustments, for a 2004 955i,there are some threads but not exactly what I was looking for.So it's question time
I'm doing the valve adjustment,first time on my Triumph,although have done it several times on Yamaha bucket and shim set up.
I've noticed there is no slot on the bucket for a special tool to hold down the bucket while the shim is extracted,even though I have bought the special tool online a while ago for 2004 955i valve adjustmenting.In my manual it says I'm gonna take out the cams, I'm okay with that.
But
While its apart,has anyone ever swaped out the buckets for ones with slots to make the next valve adjustment easier and quicker?
Faster, faster, faster, until the thrill of speed overcomes the fear of death…
My Bike: 2004 Triumph Daytona 955i / 2000 TT600
My Photo's so far...
http://www.triumphrat.net/memberalbu...0/ppuser/16612
tri955i is offline
post #2 of 36 (permalink) Old 01-19-2013, 08:10 AM
Main Motorcycle: Triumph
the shim lives under the bucket, which is inverted so like a hat. you have to lift the bucket off, not hold it down, to remove the shim hence removing the camshafts. I don't see that a slotted bucket will work here.
rupert fridge is offline
post #3 of 36 (permalink) Old 01-19-2013, 09:12 AM
Main Motorcycle: 06 Sprint
kubbie's Avatar
Other Motorcycle: 00 TT600
+ the shims are something like 9.8mm, where the TT you have listed use the 7.48(?) shims. Want to guess how I know that!
kubbie
"I'll call you if you need me"
kubbie is online now
post #4 of 36 (permalink) Old 01-19-2013, 09:33 AM Thread Starter
tri955i's Avatar
Rupert......even after reading my service manual , I did not pick up on that fact the shim is under the bucket, I did a yamaha years ago where the shim sat in a recess ontop of the bucket.Sure was simple.
Don't mind takin cams out, but the shim ontop design would have been much easier.Oh well, heats on in garage and beer in the fridge.Might be a good day
tri955i is offline
post #5 of 36 (permalink) Old 01-19-2013, 09:34 AM Thread Starter
tri955i's Avatar
Sounds like you suggesting not to try to swap shims around between the Daytona and the TT.
Noted !
tri955i is offline
post #6 of 36 (permalink) Old 01-19-2013, 09:38 AM
shim on top was the way a few years ago. shim under bucket is supposed to wear less and is the current way of doing it.
post #7 of 36 (permalink) Old 01-19-2013, 09:45 AM Thread Starter
tri955i's Avatar
Thanks for the info..........off to the garage now some cam extraction fun.
tri955i is offline
post #8 of 36 (permalink) Old 01-19-2013, 11:26 AM Thread Starter
tri955i's Avatar
it's so small :)
Wow!..........okay , so that was unexpected.Last time I did valves ( bucket/shim ) style , the shims were about inch in diameter and on top of the bucket.Thanks to Rupert, I found out before hand the shims are now better located under the bucket....and they are small.!
So I have a shim replacement chart that came with the special valve adjustment tool (that doesn't work).Not sure if I trust it now, there's not one in my service binder either
Does anyone have one they would attach and post to me.?
tri955i is offline
post #9 of 36 (permalink) Old 01-19-2013, 11:48 AM
do you have the workshop manual?
forget that.... I thought there was one in there but there isn't.....
post #10 of 36 (permalink) Old 01-19-2013, 11:58 AM Thread Starter
tri955i's Avatar
No...there isn't one in there . your right. The chart I have came with the tool , its good for vin#'s below my bike, I wonder if the shim tolerences are the same
tri955i is offline
Valve shims Hilts Air Cooled Twins Technical Talk 29 07-28-2011 12:46 PM
Shims under buckets CafeDave Air Cooled Twins Technical Talk 5 05-27-2008 06:24 PM
which valve shims to use? Speedblue2 Air Cooled Twins Technical Talk 3 10-23-2007 04:24 PM
Valve Shims... vdlcinc Sprint Forum 8 06-16-2006 11:33 PM
Valve Shims denny Maintenance & Workshop Talk 9 08-28-2004 09:38 PM
