Funky noise when starting
Well the title says it all. Its a '98 t595 when I go to start the bike it sounds as if a loud knock like a rod has been thrown. I know its not a rod because it was running a few days ago and no noise only when starting. Well today same noise except now the starter is spinning and after a few spins the engine will turn over then the motor doesnt spin only the starter. Has my sprag gone out or bad starter or battery or combination of all. Ive replaced the sprag in my Aprilia not too bad, how bad is it to replace in these? Any other part # that will work/ cheapest. Thanks guys.
