Common parts on 06daytona 955&06st1050
I have both a 06 D955 motor and a 06 Speedtriple 1050 motor,I am pondering using a 1050 crankshaft and upper case half with D955 rods,pistons,cams and camchain along with D955 exhaust header and ecm,I plan on installing this in a 06D955 frame,I've heard the case's are compatable but am unsure if rod jounals are the same diameter,does anyone out there know for sure?I do plan on matching the cam chains up for comparision and claying the piston to valve to make sure the Daytona cams aren't making to much lift.This seems like a quick way to increase displacement and power as both motors make maxim h.p. and trq. at 10700rpm,if the afore mentioned rpm isn't exceeded the 1050 crank should hold up ..right?Any thought's welcomed.Alloymotor.
