hi bar conversion - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-21-2012, 10:42 AM   #11 (permalink)
Main Motorcycle: Versys 650
Other Motorcycle: Daytona 955i
It's alive!!!!! At last found the right one to click on, why don't they write all their instructions in English instead of GeekSpeek
Uploaded with ImageShack.us
expatmanxman is offline   Reply With Quote
Old 11-21-2012, 10:46 AM   #12 (permalink)
just enough clearance for the switchgear on the tank
and just clears the fairing
Old 11-21-2012, 10:48 AM   #13 (permalink)
not sure about the clutch cable, long enough but not pretty, might try 955 Tiger one and route round front of yoke
Old 11-21-2012, 10:50 AM   #14 (permalink)
Throttle cables go through frame under tank, action a bit stiff, again might try 955 tiger cables
Old 11-21-2012, 11:32 AM   #15 (permalink)
Main Motorcycle: 98 T595
Ahks's Avatar
I love it.
I'll be drilling and reinforcing the OE triples to the same effect.
Did all the controls reach except the brake hoses?
Ahks is online now   Reply With Quote
Old 11-21-2012, 11:52 AM   #16 (permalink)
Brake pipes needed changing, speed triple clutch cable, original throttle cables. Had to extend the wiring to the left hand bar switchgear. Also had to make little bracket for brake fluid reservoir but that was easy. Ignition switch is not fastened to top yoke so no problems there. Not sure I'd bother with drilling an original daytona yoke, the top face isn't flat which makes it very difficult. Search ebay for an S3 is much easier option.
Good luck whichever way you try, it's transformed the riding experience for the better.
Old 11-21-2012, 02:21 PM   #17 (permalink)
Ahks's Avatar
I converted my CBR to handlebars. Having to machine a flat spot for the risers to mount isn't an issue Just takes a while using my drill press as a mill Luckily "cheap" weighs more than "fast" in my accounting of things.
Old 11-22-2012, 11:43 AM   #18 (permalink)
When I bought my bike it had an early version of this fitted
http://www.topyokes.com/comfort_kit/412
It wasn't well designed, the rear of the yoke fouled the tank so prevented full steering lock. It could be modded to fit by anyone who has the skills, needs the rear machining/filing away and maybe the posts modified. If anybody wants it they can have it for the price of postage.
Old 11-22-2012, 12:15 PM   #19 (permalink)
Just been looking on Triumph partfinder and seems the tiger 955 doesn't have the same throttle mechanism but the 1050Tiger does so think 1050 Tiger throttle cables are a better bet.
Also checked clutch cables, Speed Triple and Daytona are same part number, no wonder it's tight with these high bars. Tiger cable when I get round to it.
Old 11-22-2012, 12:43 PM   #20 (permalink)
Ahks's Avatar
Good sleuthing, I'm wondering if Tiger brake hoses would do as well. May be too long
CNC bar conversion. DocW Daytona Deliberations 1 12-10-2011 12:46 PM
Another 6 Pot Conversion... MuzTheInfidel Sprint Forum 17 01-02-2008 06:58 PM
Considering LSL bar conversion.... Reppyboyo Triumph SuperSports 12 07-24-2007 04:47 PM
Conversion?!... What Conversion?! Grae_ST Sprint Forum 6 07-06-2007 12:44 AM
520 conversion??? Limey Speed Triple Forum 4 01-04-2007 11:07 AM
