Time for a battery - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearMotorcycle.com Classifieds!
Old 10-14-2012, 10:21 PM   #1 (permalink)
Main Motorcycle: 2002 Daytona 955i DSSA
sardinecan's Avatar
Other Motorcycle: 1987 Honda VFR700
Extra Motorcycle: 1975 Kawasaki Z1 900
Time for a battery
My battery is finally testing weak on the load tester. The other day it started really slow on a colder morning after sitting for only a week. I know the charging system is A-OK now, but the battery is due.
My question is; where can I find the best deal on a replacement? My current battery is a Yuasa YTX14H-BS. I'd like the same or another with comparable quality at a great price. Thanks!
Romans 10:9-10
sardinecan is online now   Reply With Quote
Old 10-14-2012, 10:34 PM   #2 (permalink)
Main Motorcycle: 09 Bonneville T100
Other Motorcycle: 72 Honda CB 500
Upgrade to a glass mat battery AutoZone sell's East Penn. Just call them up or go into the store with your part number.
Timmy T100 is offline   Reply With Quote
Old 10-14-2012, 10:48 PM   #3 (permalink)
Main Motorcycle: '04 D955i (sold)
bradtx's Avatar
Other Motorcycle: '98 T595
The Wal-Mart ES14BS is an AGM battery that has worked quite well in three different motorcycles. They're made by Johnson Controls. Surprising what you find when you need a battery when nothing else is open and it's good. My '98's is now about two years old.
Brad
Battery acid is installed by the consumer, I like that.
Old 10-16-2012, 12:31 AM   #4 (permalink)
sardinecan's Avatar
Thanks guys I'll check those out.
Do you think I need the 240 CCA of the high performance battery (like the Yuasa), or is a 200 CCA battery sufficient?
Romans 10:9-10
Old 10-16-2012, 07:50 AM   #5 (permalink)
bradtx's Avatar
I like the idea of the additional 40 CCA, but a battery rated at 200 CCA is plenty.
Brad
PS The Shorai LI battery seems to be popular choice lately in my area. Pricey and long term reliability still iffy, but likely good.
http://www.batterymart.com/p-shorai-...n-battery.html
Old 10-16-2012, 01:13 PM   #6 (permalink)
sardinecan's Avatar
Brad
Whoa! That battery is sweet! Just over 3 lbs and 315 CCA! The $$$ makes me go too! lol
Romans 10:9-10
Old 10-22-2012, 01:57 AM   #7 (permalink)
Supernova
Main Motorcycle: 2011 Sprint GT 1050
DaveM's Avatar
Extra Motorcycle: Previously - Many
I have one of those Deka Gelmatt jobs in my Daytona and had one in my old 04 Sprint ST.
Seemed like a good unit.
But I like the look of these new lightweight Shorai things.
Cheers
Dave
Sent from my Motorcycle iPhone app
My album click here;
http://www.triumphrat.net/memberalbu...er/2712/sort/3
Old 10-22-2012, 03:49 PM   #8 (permalink)
What did you end up buying?
I bought a Ballistics Performance battery:
Had it in for about a month now, no issues starting, even in 49f weather. Better quality than Shorai as well.
DSSA955i is offline   Reply With Quote
Old 10-22-2012, 09:47 PM   #9 (permalink)
Main Motorcycle: '98 T595 Daytona
Other Motorcycle: '01SV650S sold
Just wondering what you are basing your statement on quality differences between Shorai and Ballistic. Did you own a Shorai and not like?
Felony is offline   Reply With Quote
Old 10-23-2012, 08:30 AM   #10 (permalink)
I base it on a multiple reviews concerning the two and owning a Ballistics the following points are what I have found. I will say however, that the Shorai batteries in reviews I have read put out "slightly" higher voltage, like .1-.2, however both are far better than lead-acid batteries.
First and the biggest strike is against the Shorai terminals that were terrible and flimsy, they broke, and bent, and did all kinds of nasty things. Shorai did however fix this with a revised terminal design, so props to them.
Second, the internals of the Shorai are essentially the same thing as the Ballistic, however, it is a significantly larger and heavier package, raising the question of why are Shorais so big? Neither has an over discharge curcuit so it's clearly not that.
Third, and most important to the life span of the battery, as of last time I looked, Shorai does not have a balancing terminal on their batteries. Without this you cannot refresh the battery to new and extend it's life and accurate power delivery. Ballistic batteries have this terminal.
Either way, I think both would suite well, however the Ballistics 8 cell is significantly smaller and lighter than the Shorai, while providing the same function at similar price point with the potential for longer life.
Time for a new battery RipxST Speed Triple Forum 14 05-09-2012 05:24 PM
Time for a new battery...this is the most extensive test I've seen on motorcycle batt lospice1 Speed Triple Forum 8 11-22-2011 02:12 PM
New Battery time!!! Derswede T3 Sport / Touring Forum 24 10-27-2010 09:58 PM
Time for a battery??? STcharlie Sprint Forum 7 09-07-2005 09:46 AM
Battery Dies every time bike sits for 2-3 days. Sprint Forum 10 09-22-2004 07:28 AM
