Time for a battery - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
Old 10-23-2012, 10:52 AM   #11 (permalink)
Senior Member - Site Sponsor
Main Motorcycle: 1968 Bonneville T120
Wolf's Avatar
DSSA955i - can you clear your PMs - I'm trying to reply to you but keep being told you have exceeded your stored quota so no new messages can be sent. Sorry for the thread hijack!
Regards
Peter Sorrell
Trident Exhausts
www.trident-exhausts.com
Triumph Only Exhaust Specialists
Wolf is online now   Reply With Quote
Old 10-29-2012, 12:45 AM   #12 (permalink)
Main Motorcycle: 2002 Daytona 955i DSSA
sardinecan's Avatar
Other Motorcycle: 1987 Honda VFR700
Extra Motorcycle: 1975 Kawasaki Z1 900
Still haven't made my battery purchase. I have a couple questions about the Ballistic.
1) What did you pay for it?
2) Since it's smaller what do you do to prevent it from shifting around in the battery box?
Thanks.
Romans 10:9-10
sardinecan is online now   Reply With Quote
Old 10-29-2012, 12:58 AM   #13 (permalink)
sardinecan's Avatar
Man I like the benefits of the Ballistic. The only issue keeping me from getting one is wanting the balance charger to go with it. That's another $80.
Romans 10:9-10
Old 10-29-2012, 10:32 AM   #14 (permalink)
Main Motorcycle: '98 T595 Daytona
Other Motorcycle: '01SV650S sold
Thanks.
2) The Li battery usually comes with foam packing that can be placed around the battery in your battery box. I know Shorai batteries come with it.
Felony is offline   Reply With Quote
Old 11-07-2012, 11:32 PM   #15 (permalink)
From what I've read, the Shorai charger plugs into the battery and has the capacity to balance charge. No need for an extra terminal to do so.
Old 11-10-2012, 03:52 PM   #16 (permalink)
Supernova
Main Motorcycle: 2011 Sprint GT 1050
DaveM's Avatar
Extra Motorcycle: Previously - Many
So Sardinecan what did you go with?
I am very happy with the performance of my Gelmat type Deka battery but like the weight savings on these new dry-cell batteries.
Next time I need a new battery I'll be plumping for a Shorai or Ballistic, unless there is something even better by then.
Now my charging system is fully upgraed, ststor, mosfet reg/rec and heavier guaghe rerouted wiring etc I hope my Deka lasts for ages
cheers
Dave
My album click here;
http://www.triumphrat.net/memberalbu...er/2712/sort/3
Old 12-22-2012, 10:35 PM   #17 (permalink)
sardinecan's Avatar
cheers
Dave
Hi DaveM - I finally got around to replacing my battery about a week ago. After hemming and hawing and wanting to get the Ballistic I ended up with a Yuasa YTX14H-BS, same as I had before for $77 USD shipped to my door.
I just couldn't justify the Ballistic, mainly because of the extra money on a special charger (I know you don't have to have it, but I would have wanted it). Plus I may have needed to fiddle with my negative lead from the R/R and it was more trouble than it was worth.
The Yuasa is the high performance series and is rated for 240 CCA if I recall correctly. Started the bike real good the other morning in low 30 degree F weather.
Romans 10:9-10
Old 12-23-2012, 12:07 PM   #18 (permalink)
Main Motorcycle: I can't decide!
Hypurone's Avatar
Other Motorcycle: Ducati Monster S4RS
Originally Posted by DSSA955i View Post
Second, the internals of the Shorai are essentially the same thing as the Ballistic, however, it is a significantly larger and heavier package, raising the question of why are Shorais so big? Neither has an over discharge curcuit so it's clearly not that. Not true. You need to do some more reading. The Shorai's use prismatic cells vs the cylindrical cells (used in power tools!) in the Ballistic. The Ballistic can't even crank my Thruxton! 3 of them failed to do so and the Shorai has worked perfectly
Third, and most important to the life span of the battery, as of last time I looked, Shorai does not have a balancing terminal on their batteries. Without this you cannot refresh the battery to new and extend it's life and accurate power delivery. Ballistic batteries have this terminal. Shorai has an internal charge level regulator/balancer, you don't even need the special charger you need with Ballistic
Either way, I think both would suite well, however the Ballistics 8 cell is significantly smaller and lighter than the Shorai, while providing the same function at similar price point with the potential for longer life. ?? Significantly ??
specs for the 8 cell Ballistic:
Dimensions (Standard): 4.5" (L) x 2.5" (W) x 4.25" (H)
Weight: 768 grams (1.7 lb)
CCA: 275
Specs for the Shorai equal:
Dimensions: 5.83L x 2.6W x 4.13H
Weight: 1.88lb
CCA: 270
Just need to play devil's advocate here and not attacking you in any way.
I have had the complete opposite experience with Ballistic and Shorai. I bought Ballistics for both bikes and while it worked for about a month in the Monster (11.4:1 compression) it started failing shortly after and I replaced it with a Shorai which hasn't missed a beat. As mentioned, 3 new Ballistics wouldn't even crank my lower compression Thruxton motor right out of the box. Installed a Shorai and cranked perfectly. Now I have a 944cc kit with higher compression (11:1) and the Shorai is still cranking strong every time....
Chuck
'10 Thruxton 944cc - In the Faster Color
"Ridin' It Like I Stole It"
Hypurone is offline   Reply With Quote
Time for a new battery RipxST Speed Triple Forum 14 05-09-2012 05:24 PM
Time for a new battery...this is the most extensive test I've seen on motorcycle batt lospice1 Speed Triple Forum 8 11-22-2011 02:12 PM
New Battery time!!! Derswede T3 Sport / Touring Forum 24 10-27-2010 09:58 PM
Time for a battery??? STcharlie Sprint Forum 7 09-07-2005 09:46 AM
Battery Dies every time bike sits for 2-3 days. Sprint Forum 10 09-22-2004 07:28 AM
