Electrical Problem 955i - Page 4 - Triumph Forum: Triumph Rat Motorcycle Forums
Old 10-21-2012, 03:59 AM   #31 (permalink)
Legend
DEcosse's Avatar
Unless the user has the correct tools and skills, DIY of the connections can often end up creating more issues than solves - that is why I recommend to purchase the OEM cable (and because it is great value!) or go with cables pre-made by someone skilled in such assembly .
Old 10-21-2012, 04:35 AM   #32 (permalink)
Excellent point.
Of course, I had a good teacher: A certain Scottish-American with French connections!
DeanRider is offline   Reply With Quote
Old 10-22-2012, 01:50 AM   #33 (permalink)
Supernova
Main Motorcycle: 2011 Sprint GT 1050
DaveM's Avatar
Extra Motorcycle: Previously - Many
Originally Posted by DeanRider View Post
Excellent point.
Lol Dean you make it so hard to guess who that might be!!!
Not 😊
Cheers
Dave
Sent from my Motorcycle iPhone app
My album click here;
http://www.triumphrat.net/memberalbu...er/2712/sort/3
Old 11-13-2012, 09:09 PM   #34 (permalink)
Main Motorcycle: Daytona 955i
Update
The Yamaha R/R and the Triumph Link Lead finally arrived so installed them today. At idle I'm getting 13.45V and at 5000rpm it's 13.5v, which is less than .5v more than the original R/R readings, the new R/R is much cooler than the original. I'm thinking that I need to do the direct wire from the R/R to the battery with the in-line 30amp fuse as I'm hoping to run both a heated vest and heated grips so I think I'll need more power.
Does this mean that the plug from the wiring harness that plugs into the R/R is left redundant and all the fuses remain the same in the bike?
Coventry Kid is offline   Reply With Quote
Old 11-13-2012, 10:03 PM   #35 (permalink)
Legend
DEcosse's Avatar
Take bike for a good run and measure again
Yes, if you wire directly to battery just leave all main harness wiring as is and simply connect R/R outputs to battery instead of the connector plug
Old 11-13-2012, 11:39 PM   #36 (permalink)
Okay - thanks. It may be a few days before I get to get out for a ride - I'm living in the rainforest on the Wet Coast!
Old 12-09-2012, 10:56 PM   #37 (permalink)
Finally had the time to complete the R/R & link lead direct to the battery modification. Now I'm getting 14.2v + at idle and at 5000rpm. Here's a couple of photos of the modification - modified the Triumph link lead and made up an aluminum heat sink mounting plate. Now just have to sort out the cold start issue!
Electrical Problem Nuke93 Daytona Deliberations 10 07-24-2011 02:03 AM
955i electrical problem? twoloads Daytona Deliberations 2 05-01-2011 05:46 PM
First electrical problem quagmire Classic, Vintage & Veteran 10 09-11-2009 07:31 AM
Odd electrical problem Lizard King Hinckley Classic Triples 6 07-16-2009 10:56 PM
So I just fixed my 955i wiring harness problem and now my 675's got the same problem. jrelloway Daytona675 Forum 21 12-07-2008 06:44 PM
