Fuel Level Indication - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.comMotorcycle.com Classifieds!
Old 10-07-2012, 04:33 PM   #1 (permalink)
Legend
DEcosse's Avatar
See this thread for information on a really neat Fuel Level Indicator - will work on all the FI Daytona models
http://www.triumphrat.net/speed-trip...ndication.html
Enjoy!
Old 10-09-2012, 09:40 AM   #2 (permalink)
Main Motorcycle: '04 D955i (sold)
bradtx's Avatar
Other Motorcycle: '98 T595
DEcosse, That is a neat little gizmo! Thanks for sharing.
Brad
Old 10-09-2012, 10:53 AM   #3 (permalink)
Legend
DEcosse's Avatar
Isn't it amazing?
Even on a T595 or Gen 1 955 (mech speedo) is still very functional for Fuel Level, using the Tach only - to be honest, the basic install without the LCD gives excellent functionality, for Fuel Level (%), Actual Fuel Used or Actual Fuel Left, even without having a mileage recorder via an electronic speed sender.
The mpg and distance to empty are nice bonuses with the digital speed input model, but aren't exactly necessary.
Old 10-10-2012, 03:30 AM   #4 (permalink)
Main Motorcycle: 05 Tiger
Other Motorcycle: 2006 Daytona 955i
Very nice!
The fuel sender on my Tiger has been pooping the bed progressively to the point where my low fuel light didn't come on and i ran out last week.
Do you think this could be made to work on an 05 Tiger (Sagem FI)?
Cos_07 is offline   Reply With Quote
Old 10-10-2012, 08:36 AM   #5 (permalink)
bradtx's Avatar
Originally Posted by Cos_07 View Post
Very nice!
From DEcosse's link, yes. With a digital speedo it can be 'full featured'. For those of us with a worm driven speedo an auxilliary input (countershaft sprocket) can be fabricated for MPG data.
Brad
Old 10-10-2012, 11:25 AM   #6 (permalink)
Legend
DEcosse's Avatar
...Do you think this could be made to work on an 05 Tiger (Sagem FI)?
Absolutely!
The only difference I can see would be the mileage counter - the Tiger has the 19" wheel, right?
Old 10-10-2012, 02:46 PM   #7 (permalink)
Main Motorcycle: 2002 Daytona 955i
Did you have to request one to be specially made to work with 3 cylinders?
Dartdude is offline   Reply With Quote
Old 10-10-2012, 04:12 PM   #8 (permalink)
Legend
DEcosse's Avatar
Yes, you will have to state the model that you have so that you get a Triumph specific unit with the pre-established constants already But will not have to be 'specially made' - the scaling is already done, having been derived from my bike and will work 'out of the box'.
But even when installing the one 'calibrated' with the constant originally set-up for the SV (2 cylinder 650) it can be calibrated for whatever it is fitted to within one tank of gas.
It computes like this: every time the injector pulses, it measure the duration that it is open (it opens for different periods of time depending on how much fuel the map table tells it to deliver) - so what it does is set up a counter to calculate the total duration of time that the injector is open and this very accurately translates to volume of fuel;
so by starting with full tank, when you refill you input the fill volume and it correlates to the total duration of injector pulses and recalculates the constant i.e. the calibration factor.
But as said, now that I have already supplied the information, it will be there as starting condition for the Triumphs, so even that very first tank will be reasonably accurate (although can still be tweaked for your own bike by same method)
The miles recorded were also slightly off (165.5 on the Triumph vs 161.5 on the FuelBot over the course of one 'fill'), due to the slightly larger front tire on the Triumph; however that constant will also be updated on the Triumph unit so should align to your OEM odo.
Old 10-10-2012, 05:50 PM   #9 (permalink)
Originally Posted by DEcosse View Post
Absolutely!
Yep.
It'll cost about 80 Euro to get a new fuel sender unit and this looks better and more accurate for the same kind of money.
Old 10-15-2012, 07:27 PM   #10 (permalink)
Main Motorcycle: '98 T595 Daytona
Other Motorcycle: '01SV650S sold
I'll be getting one for my '98.
Felony is offline   Reply With Quote
FuelBot - Fuel Level & MPG Gauge DEcosse Speed Triple Forum 30 04-18-2013 08:11 PM
955i ST fuel level Calveitro Sprint Forum 15 07-14-2012 02:45 AM
fuel level gauge showing random fuel levels DesmoBanana Sprint Forum 6 06-07-2011 08:00 AM
Fuel level Bigngreen Tiger Workshop (archive) 7 11-22-2008 04:37 AM
Float level / Fuel Level for 1998 Trophy 900? CharlestonRider Trophy 8 06-04-2005 04:07 PM
