Gearing - Triumph Forum: Triumph Rat Motorcycle Forums
Old 08-22-2012, 03:11 PM   #1 (permalink)
Main Motorcycle: 2002 Triumph Daytona CE
Gearing
I have a 2002 Triumph Daytona 955i CE and stock gearing on it is 18/42. I've discovered the past owner put a 43T rear sprocket in it, I'm thinking of putting a 19T front on to try to get some of that top end back again, the bike is torquey as hell the way it is now so I dont mind losing some of that for some good high RPM pulling on the highway. Any ideas/suggestions on this? Will the engine and the power be happy with this? The bike has a modified airbox with a K&N and TOR carbon can if that helps
DiabloFormula is offline   Reply With Quote
Old 08-22-2012, 03:49 PM   #2 (permalink)
Main Motorcycle: 2002 Daytona 955i DSSA
sardinecan's Avatar
Other Motorcycle: 1987 Honda VFR700
Extra Motorcycle: 1975 Kawasaki Z1 900
If you would rather have the top end gearing and lower RPM's go for it. Not sure if you would need a longer chain though. You could always just go back to a 42T rear, but I'm sure it's more expensive to do so. I always save my gearing change decisions for when it's time for chain/sprocket replacement, but that's just me.
Romans 10:9-10
sardinecan is online now   Reply With Quote
Old 08-22-2012, 04:01 PM   #3 (permalink)
I always check out the ratio changes, top speed etc on: http://www.gearingcommander.com/
For reference here are the final ratios: 18/42 = 2.33 // 18/43 = 2.39 // 19/43 = 2.26 // 17/43 = 2.53
2.26 >> More Top End Speed >>
2.53 << Faster Acceleration <<
DeanRider is offline   Reply With Quote
Old 08-22-2012, 04:04 PM   #4 (permalink)
Originally Posted by DeanRider View Post
I always check out the ratio changes etc on: http://www.gearingcommander.com/
Ya i did that and like what the numbers come out to be, just wasnt sure if anyone had real world experiance with that combo.
Old 08-22-2012, 04:20 PM   #5 (permalink)
To my mind the ratio difference between stock [2.33] and what you have at present [2.39] would be fairly minimal.
Old 08-22-2012, 06:28 PM   #6 (permalink)
Main Motorcycle: '04 D955i (sold)
bradtx's Avatar
Other Motorcycle: '98 T595
DF, More than likely your engine can't pull top to redline as it is. A 19T C/S sprocket will make it less likely. The most popular non OEM gearing caters to the strong mid range these engines have; SSSA combos include 18/45, 17/45, 17/43 and 17/42, DSSA combos include 19/46, 18/46 and 18/44.
Brad
Old 08-22-2012, 06:38 PM   #7 (permalink)
Main Motorcycle: S1 Lightning
02Daytona955i's Avatar
Other Motorcycle: '96 FXDL
Extra Motorcycle: DRZ400S
18/46 and 18/44.
Brad
Will the 18/46 fit with the stock chain?
Thanks
Hard to know exactly what people mean by 'the real world'. Whatever it is, this is the primo sports bike for it. Plenty of everything and that triple howl! Sept 03 T.W.O.(Triumph Daytona955i)
02Daytona955i is offline   Reply With Quote
Old 08-22-2012, 06:46 PM   #8 (permalink)
bradtx's Avatar
Thanks
Nope. I think 112 links were ordered and then trimmed to fit.
Brad
Old 08-23-2012, 04:19 AM   #9 (permalink)
Main Motorcycle: 05 Tiger
Other Motorcycle: 2006 Daytona 955i
Brad
If the stock gearing is 18/42 on the SSSA, i'm running 18/44 on mine, stock chain.
Cos_07 is offline   Reply With Quote
Old 08-23-2012, 07:08 AM   #10 (permalink)
Brad
Ok, thanks Brad.
I've got a 18 front on right now, so I'll go ahead and bust open the 45 rear I ordered last week.
Ahhh, all the little 'problems' we're so lucky to have!
TBS Gearing BigBadBadge Hinckley Classic Triples 5 05-26-2010 03:09 AM
Gearing on the ST el paso Street Triple Forum 7 09-21-2008 08:06 PM
17/45 gearing Qual Speed Triple Forum 6 03-15-2006 11:15 AM
gearing again devrep Club Cafe' 0 11-18-2005 11:09 AM
Gearing Nickwiz Daytona Deliberations 8 09-22-2005 07:58 AM
