Originally Posted by sardinecan
Thanks. Yea I read through that section before I posted. That's what got me confused as to why I would need to remove the tail section? Unless I'm reading it wrong. Don't mean to make it harder than it is, I like to follow things to the letter and sometimes to my detriment.
All you need to remove are both saddles, the CF trim panels under the tank and then the tank using the above info. It really is easier than it reads. One tip is to have as little fuel as possible in the tank to make manipulating it easier. Another tip is to keep track of which hose goes where on the LHS of the tank.
Brad
