I tried some LED taillights in my TT600. They were dimmer than the regular bulbs. Maybe they were the wrong LEDs, so your project should work OK. One of the things I did was check resistance. A regular bulb is a bit over 5 ohms. The LED has no resistance that I could measure. I would expect that if you put a 5 ohm resistor in series with your LED turn signals, it would work fine.
Let us know how it works out.
Will
