hi all! been hanging around for a while and the day has come where i need to seek the advice of fellow daytona owners!
the rear brake caliper on my '94 900 is just about dead on its legs- corroded bad- the retaining groove for the scrapper seal is breaking away and the seal is unsupported.
triumph-ant seem to be the only solution i can find/afford!
however opinion seems to suggest that its not the best design for a caliper
so!- does anyone have a rear caliper knocking around they want to sell?!
or
can anyone suggest a good upgrade of caliper? and where to source one?
Sprint Manufacturing will probably be able to sort you out with a good secondhand one..
01985 850821 www.sprintmanufacturing.co.uk
they usually do next day delivery.
good luck
cheers mate- tried sprint manu, but they couldn't help. had everything but caliper!!
i'm also trying to find out if there are any other calipers that are a direct fit, as the standard ones seem to have a few design flaws!!
