fuel pump problem? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 24 (permalink) Old 05-18-2010, 06:02 PM Thread Starter
Main Motorcycle: 97 Daytona Triumph T595
fuel pump problem?
97 daytona triumph
Bike wont start, seems like not getting fuel. turn key and i dont hear the fuel pump prime up. checked fuses and they are all good. I just want to make sure its the fuel pump before i pay $200 bucks for one. Ever fuel pump i ever come close to makes a noise when key is turned to the on position. this one on my bike does not. checked the plug that the fuel pump plugs into and it has power. I dont know if relay has anything to do with fuel pump or not. So, to me it seems like the fuel pump is no good.
Is that the problem?
If so is there any aftermarket fuel pumps i could get that is cheaper? ( i am having a hard time finding after market parts for this bike.)
Thank you
Jay
97daytri is offline
post #2 of 24 (permalink) Old 05-18-2010, 07:20 PM
DEcosse's Avatar
Originally Posted by 97daytri View Post
.... checked the plug that the fuel pump plugs into and it has power. I dont know if relay has anything to do with fuel pump or not. ...
You're checking for power at the fuel pump connector plug during first few seconds after turning ignition on? After that first few seconds there should be no power there.
If you do indeed, have power at the connector for first few seconds then pump should run.
My pump - similar gen to yours as original T509 tank/pump - is very quiet compared to my Suzukis, but still quiet audible when ignition first turned on.
DEcosse is online now
post #3 of 24 (permalink) Old 05-18-2010, 07:39 PM Thread Starter
ya we checked it when the key was turned to on position. My brother and i both could not hear anything. We placed hand on pump and felt no vibration or anything.
so its looking like i need a new pump?
97daytri is offline
post #4 of 24 (permalink) Old 05-18-2010, 07:47 PM
DEcosse's Avatar
Are you checking power and ground at the connector plug?
i.e. measuring the voltage acoss the two connector pins?
Or measuring the + power with respect to the battery negative?
Could be the ground wire that is broken - so make sure you are measuring both pins at the connector.
If that proves good, would have to say pump is most likely a problem.
If not, then pursue the missing ground return.
post #5 of 24 (permalink) Old 05-18-2010, 09:03 PM Thread Starter
checked to see if power was acoss the two connector pins
97daytri is offline
post #6 of 24 (permalink) Old 05-18-2010, 10:33 PM
Main Motorcycle: 1998 T595
bradtx's Avatar
97daytri, Make sure the engine kill switch is on. If so, swap the fan relay with the fuel pump relay (two middle, front row on my '98). The fuel pump relay should operate under control of the ECM for a 2-3 sec. span and the relay operation is easily felt and heard.
Brad
bradtx is offline
post #7 of 24 (permalink) Old 05-18-2010, 10:36 PM
Other Motorcycle: 2000 Yamaha RoadStar
I just bought a T595 and it died on me after I put 100 miles on it.... So I took the whole tank off and apart, and it turns out that it was a $10 relay for the fuel pump. So after I took the tank apart and changed the filter out, I just replaced all 3 of the same relays. Definitely check the relay first, and I wouldn't buy the Triumph one for $30, just take the relay to an old-school bike shop or auto parts store...
53fireman is offline
post #8 of 24 (permalink) Old 05-18-2010, 11:57 PM Thread Starter
would it be the relay, if im still getting power at the plug?
97daytri is offline
post #9 of 24 (permalink) Old 05-19-2010, 12:27 AM
DEcosse's Avatar
Power can only get to the plug by being switched by the relay, so no.
post #10 of 24 (permalink) Old 05-19-2010, 08:06 AM
Main Motorcycle: daytona t595
triple595's Avatar
Other Motorcycle: thruxton
Extra Motorcycle: triumph tiger
another thing to check is if the pipes have come off in the tank, once youvwe discounted the relays
triple595 is offline
Question about the fuel connectors attached to the fuel pump mounting plate zapata Speed Triple Forum 2 11-16-2008 11:11 PM
fuel pump nige-s Speed Triple Forum 4 04-22-2008 01:15 PM
Help! Fuel Connector/Fuel Pump LeDude Speed Triple Forum 2 09-18-2006 10:58 PM
Fuel Pump Problem on 98 S3 scouselee Maintenance & Workshop Talk 0 02-11-2006 06:59 PM
fuel pump and fuel injectors speedmerlau The Rocket Science Forum 5 11-01-2005 02:12 PM
