Originally Posted by DEcosse
Yes, but they changed the design of the stem nut and triple clamp on the 04 so you might need to replace that also if you get the last year of the S3.
Also - not sure how much clearance you get with the fairing on the 02+ Daytona with upright bars - definitely better than the 97-01 but not sure how much height you will be able to accommodate
I know this thread is old but is there any way I can get a picture of the new design? I can't good info anywhere. I'm currently making a Speedtona but I bought a top triple clamp with a (prox) 22mm stem hole instead of the 25mm stem hole (which uses the 6 hole round funky nut) that my Daytona uses. I'm really hoping I just need to get a different nut.
