Fixed low fuel warning light (sender) - Triumph Forum: Triumph Rat Motorcycle Forums
Old 03-20-2010, 09:18 AM   #1 (permalink)
Hi All,
I hope that I have put this post in the right place anyway I had a problem that I learned about the hard way when I ran out of petrol
So when I got the bike home I did all the checks to isolate the problem and found it to be a faulty low fuel sender unit, Then I un-screwed the unit from the bottom of the tank and found that the sensor at the top of the unit had come away from the metal post (see picture). I then re-soldered the sensor into position and put a small zip tie on just to make sure and it now looked as it should (see picture).
I re-installed the unit and I now have a working low fuel light so I thought I would post it here to help other members. Terry.
Fixed low fuel warning light (sender)-p180310_18.570001.jpg   Fixed low fuel warning light (sender)-p180310_18.570002.jpg
teksta1701 is offline   Reply With Quote
Old 03-20-2010, 12:09 PM   #2 (permalink)
Favourite Bike: '04 D955i
bradtx's Avatar
Other Motorcycle: '98 T595
Terry, Thanks for posting the fix! You might also wish to post here http://www.triumphrat.net/t3-sport-touring-forum/ also.
Brad
Old 03-20-2010, 03:35 PM   #3 (permalink)
Hi Brad, Thanks for the info and I will post the fix at the link you supplied. Terry.
Fuel low warning light thornley Tiger Workshop (archive) 5 06-01-2010 06:58 AM
Fuel warning light BlackCbke Speed Triple Forum 13 11-23-2006 10:54 AM
Intermittent Fault - Engine warning light & Fuel light Tassie_Tiger Tiger Chat 4 06-13-2006 09:58 AM
Engine light and erattic low fuel warning light guy71 Daytona Deliberations 12 04-17-2006 09:18 AM
My fuel waring light has fixed itself! Aussiebikerdave The Rocket Science Forum 2 07-17-2005 07:02 PM
