Originally Posted by bradtx
Saint, Did this problem start after gassing up? While it reads like a fueling problem, it reads more like a typical problem when fuel is left in the carbs and the bike has sat for a length of time.
There should be no debris of any kind, is there a fuel filter? Either debris blocking carb orifices or water will cause the engine to run lean and require a richer mixture, provided by the choke.
I'd dump what's in the tank and use some fresh gas.
Brad
No, but on saying that I've just taken it out again and it's definately getting much better. Without choke it revs ok but when I put it into gear it wont pull away but just a little choke and it starts to behave much better than before. (before I had to pull away on full choke and then take the choke of when slowing down, pretty dangerous, especially when cornering) But I'm glad I looked at this from the forums point of view (mossy) said look at the carbs and all along I thought it was a coil, (I've had so many problems in the past with pick ups coils regs etc and it felt similar)
The gas is fresh, no there is no fuel filter(I don't think anyway) not between the air filter and the carbs. After that last ride it feels a massive difference now than before (although its not right) so It must be the fuel area. I've done everything else now,except strip the carbs, I've done the air filter, the spark plugs, (they were new anyway) cleaned the carbs with carb cleaner(but only through the vents) and just now its made a marked difference so I will strip them in the next couple of days. The manual says get a carb rebuild kit so I will do that.
I have not much to give back but I will give a tip, you probably do it yourselves but in case you don't.
Because I have the fairing off and on often, especially with this bike. I always used to get the fixings and studs mixed up when putting them in a box or tin. So what I have done over the last couple of years or so is,
Get a large piece of card or open up a cerial box. Draw two views of the bike (Kerb side and Rd side). Then where the studs and fasteners go make small holes on your drawing. As you take the fasters or bolts off, push them into your card, you can fasten them as normal on the back. I've never lost or mixed up one bolt since, it's great and dead easy when you put the bike back together.
So I will strip and clean the carbs and see what happens. Will keep you posted. Thank You.
