Carbon Muffler Repack? - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.comMotorcycle.com Classifieds!Ontario TourismSportbikeTrackGearNew BonnevilleHonda Powersports
Old 03-12-2010, 03:00 PM   #1 (permalink)
Favourite Bike: 2002 Triumph Daytona 955i
Can you repack these? if so how do you do it, and where do you get the packing?
This is the on my bike has on it.
http://www.british-customs.com/trium...-silencer.html
Thanks,
2002 Daytona 955i, 8k miles all stock (for now) 12/31/2011
1998 Daytona T595 955i SOLD
USA
mjonesjr8 is offline   Reply With Quote
Old 03-14-2010, 01:42 PM   #2 (permalink)
Favourite Bike: 08 Husky SM510R
Other Motorcycle: 02 Triumph 955i
Extra Motorcycle: Aprilia SXV 5.5
Any shop should have repack kits... alternatively you can use the regular pink stuff, it just will need repacked sooner.
Basically you just need to remove the canister (at the midpipe connection, not the tip), if rivets drill them out. Pull out whatever is left, and rewrap the perforated core with as much fiberglass packing you can get to fit... tie it up with safety wire, stuff it back in the canister and put it all back together.
Google it, some dirt bike forums will have some more detailed instructions, and if you don't feel comfortable a shop can do it for you.
wilmar13 is offline   Reply With Quote
Old 03-15-2010, 12:08 AM   #3 (permalink)
Favourite Bike: '04 D955i
bradtx's Avatar
Other Motorcycle: '98 T595
mrjonesjr8, The allen screws retaining the end cap are spot welded. You'll have to grind and possibly drill the heads off. I have the same TOR can on my '98, it's pretty well blown out and going to stay that way.
Brad
Old 03-31-2010, 11:32 PM   #4 (permalink)
once you get the end plate unscrewed, there is an end cap that is welded on. You would have to grind off those spots to repack. Once finished it would have to be welded back on. Not impossible, but certainly harder than most.
ROWYKO!
xactoman is offline   Reply With Quote
D1200 Muffler Repack ffry63 T3 Sport / Touring Forum 7 06-07-2009 10:15 AM
Daytona 1200 Muffler Repack ffry63 Daytona Deliberations 2 05-25-2009 11:13 AM
Sprint ST carbon fiber muffler compatibility 57rookie Sprint Forum 3 01-17-2006 05:32 PM
repack triumph carbon low pipe ryan Maintenance & Workshop Talk 2 08-08-2005 01:11 PM
