help pls - Triumph Forum: Triumph Rat Motorcycle Forums
Old 03-08-2010, 04:33 PM   #1 (permalink)
jason ffoulkes's Avatar
help pls
Hi Guys
My 1999 Daytona 955i won't start! I had it running the other week but had a fault with the clutch switch which stopped it running. I replaced switch and since than all I'm getting is a clicking noise from the starter relay. i have replaced the batery and disconnected the starter relay and put it across the battery and it works fine. After trying to start it the battery the drops to around 6v from fully charged after a couple of goes. As far as I can see all connections are ok. THe bike is in vgc and the only problem I've had before is the clutch switch.
pls help, for once it's not raining in Wales and the sun's been out!
Cheers Jason.
jason ffoulkes is offline   Reply With Quote
