Fuel vapour leak - Triumph Forum: Triumph Rat Motorcycle Forums
Old 03-07-2010, 09:50 AM   #1 (permalink)
Favourite Bike: Vincent Black Shadow
Other Motorcycle: Daytona 955i 2006
Fuel vapour leak
Hi everyone, new to this site and already I have a problem! I went to get my '06 Daytona 955i out of the garage yesterday and noticed that the paint around the fuel filler cap was all bistered and flakey. There was a strong smell of petrol and there was a stain down the side of the tank.
The bike hasn't been used much during the English winter, maybe once a month,but it has been started every week. I last ran it about a week ago and it was fine then.
I initially though that something had been spilt on it, but there is nothing that could have been split or dripped from anywhere. When I got back from the ride, the strong smell of petrol was still there. I rinsed the paintwork on the tank to prevent any further damage and it seemed as if the water was leaking into the tank through the filler cap.
I wonder if there is a problem with the seal on the cap or a breather pipe?
Any help would be very welcome!
thanks
Tim
mk1boy is offline   Reply With Quote
Old 05-16-2010, 06:20 PM   #2 (permalink)
If anyone's interested....
There are two pipes from the tank, they exit on the left side and usually appear near the bottom of the fairing by the side-stand. One is an overflow pipe in case you over-fill the tank and the other is a breather pipe. The breather has a one way valve fitted.
My problem was that both pipes had problems.
When fuel was being forced out around the filler cap, I suspected it was one of the pipes. The overflow turned out to be blocked with crud. A quick blast with an air line cured that. But the next day i noticed fuel leaking from that pipe. A lot of fuel. Around half a pint overnight. I couldn't work out why fuel was coming out of this pipe when the tank wasn't full and the pipe wasn't blocked.
It turned out that the one-way valve in the breather pipe was faulty - this meant that air wasn't getting onto the tank to replace the fuel that was used. Pressure built up in the tank and forced it through the filler cap until I unblocked the overflow - now it could blow the fuel out there. Removed the one-way valve and no more problems.
Tim
Fuel Leak Studog 00 Hinckley Classic Triples 23 09-29-2009 12:39 AM
Fuel leak and fuel valve confusion screene T3 Sport / Touring Forum 28 01-25-2009 12:03 PM
Fuel leak mglemans86 Sprint Forum 3 10-04-2007 07:24 PM
Fuel leak humbug Daytona Deliberations 10 08-18-2006 01:57 PM
Fuel Fitting O-Ring's / Fuel Leak BooneDog Speed Triple Forum 0 01-02-2006 07:34 AM
