Daytona doesn't like to go into first gear sometimes...? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 03-06-2010, 09:23 PM   #1 (permalink)
Favourite Bike: 09 speed triple
Well most of the time it goes right in but every so often it just bounces out when I try to shift in(click click click). I don't know enough about motorcycle transmissions but if it happened in my jeep I'd say the synchros were worn. Anybody else get that?
Jack's955i is offline   Reply With Quote
Old 03-06-2010, 09:26 PM   #2 (permalink)
Favourite Bike: '04 D955i
bradtx's Avatar
Other Motorcycle: '98 T595
Jack, Make sure there is isn't too much slack in the clutch cable. The adjusters are at the clutch lever and at the clutch cover.
Brad
Old 03-07-2010, 12:14 AM   #3 (permalink)
Brad
I'll check the one on the clutch cover tomorrow but I just adjusted the one on the lever to 3mm today after I flushed my coolant.
Old 03-07-2010, 06:50 PM   #4 (permalink)
ok so I double checked today. did what it said in my Haynes manual. I actually had it wrong, I thought it was 3mm at the top, its 3mm at the bottom and then you adjust the top so theres less than 1mm of slack. i did that and its a huge improvement. still doesn't like 1st from time to time. its more when i try to push it in still rolling and im going a little faster than i think i am. I'm trying to come to a stop or roll to push it in and its a bit better. maybe its just touchy.
Old 03-11-2010, 06:10 PM   #5 (permalink)
Favourite Bike: 2012 Daytona 900
Brooksie's Avatar
Other Motorcycle: 2008 Kawasaki ZX14
Jack-not sure what year you have. I had Pazzo levers on my '05 and it took a little tweaking to get them right. I had to keep the adjuster on the lever all the way from the bar or 1 click in and it worked fine after resetting the levers.
Brooksie is offline   Reply With Quote
Old 03-12-2010, 11:36 AM   #6 (permalink)
Favourite Bike: Daytona 955i
Other Motorcycle: Not yet
Extra Motorcycle: Wife's SV650
Sometimes you can have everything adjusted fine and it will still not quite link up. Roll if forward 5 inches and you are good to go.
May is going to be a busy month. Race school the 8th, Redline party on the 16th, first round of races 22nd & 23rd, and track night the 26th. Better order a couple sets of tires.
Lehbs is offline   Reply With Quote
72 Daytona slipping out of gear slimmer Classic, Vintage & Veteran 1 06-08-2009 11:30 AM
Sprag gear change Daytona 900 Targis34 T3 Sport / Touring Forum 8 05-25-2009 11:07 AM
'72 switch gear on a '71 Daytona...? Rob D Classic, Vintage & Veteran 9 06-23-2008 09:31 AM
gear selector daytona 600/650 rapid Maintenance & Workshop Talk 1 03-26-2005 03:33 PM
New Daytona 650 clunks into first gear? Kilt Triumph SuperSports 11 03-07-2005 10:54 AM
