Alternative rear master cylinders - Triumph Forum: Triumph Rat Motorcycle Forums
Old 03-05-2010, 01:24 PM   #1 (permalink)
I have a 2002 centennial 955i and was hoping to replace the rear brake system (apart from the brake itself)
What are the options available? any direct bolt replacements?
thanks for any help.
matthew
minesweeper is offline   Reply With Quote
Old 03-05-2010, 02:10 PM   #2 (permalink)
DEcosse's Avatar
Kawasaki ZX7 91-96 is direct bolt-on replacement but 1/2" vs 14mm Triumph.
Gives better braking force at the caliper - very noticeable improvement
Or you can install complete Sprint ST Rotor/Caliper/Hanger combo which will give the advantage of the bigger rotor size.
T'Rat.net BOTM November 2009
Old 03-06-2010, 10:59 AM   #3 (permalink)
Favourite Bike: '98 Daytona
Wally's Avatar
Other Motorcycle: '64 T120 in pieces
DE, that one confuses me. I've been considering the same upgrade, but a smaller piston physically cannot exert more force for a given pressure. The exact opposite is true.
Perhaps the OEM is 1/2" (12.7mm) and the Kawasaki is 14mm?
Wally is offline   Reply With Quote
Old 03-06-2010, 02:03 PM   #4 (permalink)
DEcosse's Avatar
Originally Posted by Wally View Post
.. but a smaller piston physically cannot exert more force for a given pressure. The exact opposite is true....
No - I have it correct.
This is the master - The master has applied force & a resultant pressure, not applied pressure & a resultant force (which is what the caliper does)
We're talking about increasing pressure from the master for same applied force from your foot.
That increased pressure translates to greater force at the caliper end (the caliper's piston area being unchanged)
For master:
Pressure is Force per Unit Area.
P = F/A - if A is smaller, P is higher.
For same applied force, smaller piston means greater pressure.
For Caliper:
Force = P*A
If P is now made higher (because of the smaller master piston) F is higher.
Think of the Stiletto heel analogy - woman in spike heels will leave impressions on a lino floor, vs guy twice her weight with flat 3" x 3" heels
The woman is a 'master' not a slave (or caliper)
Old 03-06-2010, 09:08 PM   #5 (permalink)
Wally's Avatar
I stand corrected...I was considering it from a hydraulics perspective where P is the constant and A is increased to yield a higher F (as in your "caliper" example).
Old 03-26-2010, 11:47 AM   #6 (permalink)
Favourite Bike: '04 Spdtrippled Tona
Ironcobra's Avatar
does this apply to an 04?
Ironcobra is offline   Reply With Quote
Old 03-26-2010, 12:42 PM   #7 (permalink)
DEcosse's Avatar
Yes, master is same.
Old 03-26-2010, 11:11 PM   #8 (permalink)
Favourite Bike: 2006 Triumph 955i Daytona
Other Motorcycle: 2002 BMW R1150RT
Extra Motorcycle: 1998 Aprilia RS250GP1
I have to split my front calipers as I'm sure I have pistons which need a look at. Does anyone know the following:
What torque figures are to be used when rejoining the halves?
What brand of brakes are on an '06 Daytona? Tokico, Nissin, Brembo?
I believe Triumph don't want anyone fiddling with the brakes but I've serviced brakes all my riding career. Is there a problem with splitting, servicing and refitting of which I'm unaware?
DEcosse or BradTX especially, have you ever split Brembo Golds and serviced? Torque figures for rejoining the halves. I can't find it anywhere.
Any help appreciated.
Linz
Linz is offline   Reply With Quote
Old 03-27-2010, 12:15 AM   #9 (permalink)
Favourite Bike: '04 D955i
bradtx's Avatar
Other Motorcycle: '98 T595
Linz, I double checked at BikeBandit and the '06's front calipers are the same Nissins as on all of the D955is.
We split the calipers on the '02 quite awhile ago, but never found a torque value for reassembly so IIRC we tightened to 25-30 Nm and so far, so good. They're very straight forward to work on and there is a seal kit for the pistons, and we went to an auto parts store for the caliper halves' seals (O rings). I've never worked on Brembos, sorry there.
Brad
Old 03-28-2010, 09:06 AM   #10 (permalink)
Thanks for that Brad. Massive help.
Cheers mate.
Linz
955i Front Brake Master Cylinder - alternative ? triple3john Speed Triple Forum 10 02-14-2009 10:26 AM
Anyone know alternative rear caliper for ST 1050? GRG-Sprint1050 Sprint Forum 9 01-25-2009 06:17 PM
Rear brake lever alternative? Aurelius Speed Triple Forum 0 10-20-2007 09:56 AM
Alternative rear signals dragonrider Speed Triple Forum 6 02-11-2007 09:34 PM
Which master cylinders work? auraaura Speed Triple Forum 2 09-19-2006 03:37 AM
