Originally Posted by XTREMESTEVE81
... Does the Triumph updated map and power commander give me a few more horses? I got my bike in 2006 and never put the updated map in it.
Originally Posted by bradtx
XTREMESTEVE81, Double check, but for a PCIII I understand it's best to use the base map. ...
It won't make any difference what starting map you used if you had it dyno tuned for the PC3 - however 'off-the-shelf' maps typically are referenced to OEM base map.
Regardless of which, at this point if you install the Triumph 'TOR Exhaust' base map, your PC3 map will be off.
Did you install the O2 sensor bypass plug?
Won't affect your mid-range & top end but without it the ECM will just 'tune around' any changes in the PC3 map at the part throttle end.
Is it a PC3 USB?
If so, did you install the Accelerator Pump feature?
Not sure how much difference that would make on the Triumph (I use Tuneboy) but on the TL, it gives you better 'snap' when you open the throttle.
The instructions for loading that are a bit vague in that they don't mention the following: - what I ultimately discovered is it will not load if you have the main program open. So close that and THEN run the utility. Note that you will need the auxiliary battery connected when you do that.
After you run it, open main program and you should see the option in the main map under tools - set it per the suggested starting condition which works well for street bike.
Are you using stock gearing?
You would also benefit from changes there - general consensus is one down at front two up at rear (net 17/44)
That will get you up in power band and improve the rear wheel torque.
