Hi,
Got a new chain and sprockets for mine the other day as the one that came with the bike was severly shagged by the previous owner. The pin I pushed out to split it was worn about 20 thou" (0.5mm) so over all those pins that equates to a lot of extra chain. The plates it goes through will also wear a similar amount so that doubles it. Then the rollers and sprocket faces will go a bit adding more. It is a whole lot better now but oddly enough, measuring the chain as in the Triumph manual, 21 pins gave a measurement just in limits. If in doubt strip the rear wheel assy and check everything for seizing and wear and also check there is nothing fouling the pinch on the swing arm and preventing it clamping up even when the bolt is tightened. At the end of the day you are putting 120 odd horsepower through that chain, it has got to be right!
Glenn.
