30amp fuse 955i - Triumph Forum: Triumph Rat Motorcycle Forums
Old 02-21-2010, 07:06 AM   #1 (permalink)
Favourite Bike: Triumph Daytona 955i
evansdavid73's Avatar
Extra Motorcycle: 2010 Bonneville SE
30amp fuse 955i
I have read a few threads on this but still none the wiser
My 05 model 955i daytona keeps melting the no2 30 amp fuse. I have had the bike checked by a dealer and they replaced the regulaor rectifier informing me that the alternator was fine and that the fuses I had put in the fuse box were cheap!! yeah ok so why do the "expensive" ones keep melting too!!?? I tried the mod suggested by DECOSSE but all this does is melt the fuse in the separate fuse holder I installed (using all the instructions i.e. 12 ga wire etc) I took the mod off and put every thing back to the way it was. Fitted a new battery and still have the fuse melting..so could there be another issue...does anyone from the factory read this and have a simple solution? I have read it could be bad connectors or a chafing wire somewhere but I have checked everything over and all seems fine........I have noticed many other people with this complaint so surely there is something inherently wrong with the wiring....anyone....anyone......
David
evansdavid73 is offline   Reply With Quote
Old 02-21-2010, 05:39 PM   #2 (permalink)
DEcosse's Avatar
Same answer as before David - sorry, it has to come down to the quality of your connections.
If you are melting the fuse enclosure before the fuse itself melts, then you do not have an over-current situation but a voltage drop situation (the combination of which, with current - which is a given - is power dissipated as heat) - that can only be caused by resistance which can only be caused by the quality of wire & the connection.
That's the whole story, nothing else.
P= V*I or P=R*I^2
I is a fixed requirement of the system so the only thing that can increase P is R (will increase V but that is consequence of R, not the other way around)
Doesn't take much since the power increases exponentially with the current.
Maybe you could include some picture of how you did the mod ...
Take your voltmeter and stick one of the probes through the insulation at the output of the R/R itself (close up to where it exits the unit) - use a needle or something if you prefer not to make a hole hole in the insulation; put your other probe on the battery positive terminal. Start bike, have high beams etc on and any other load you would typically have on your bike.
What is the voltage you are measuring?
Check at idle and also at 5K or so
p.s. of course if current demand is higher than normal that would also have an effect - but with quality fuse holder and 12ga wire, you should still not be melting anything - and obviously not drawing in excess of 30A or fuse filament itself would blow.
T'Rat.net BOTM November 2009
Old 02-22-2010, 03:48 AM   #3 (permalink)
Favourite Bike: Daytona '04
lesterg's Avatar
Hi David
As you know I was having exactly the same issue. Try the below - hope it resolves your issue.
I got some help in from a friend over the weekend and found that the ground connection on top of the block wasn't making optimum contact. Cable direct from battery negative to top of engine.
Loosened the connection, used some sandpaper to clean the lugs and point on block where this connects. Then using a spring washer to help prevent this coming loose tightened it all back in place.
The stator wires and the in line fuse now only get warm. The fuse seems to get a little hotter once the fan kicks in and the extra power is being pulled but not nearly as hot as it was getting.
lesterg is offline   Reply With Quote
HELP!! Daytona keeps blowing 30amp Fuse doofs10 Daytona Deliberations 6 02-05-2010 01:29 PM
Fuse for clock/trip/acc' socket 955i pumpkinhead456 Tiger Workshop (archive) 11 10-04-2009 03:17 PM
Main 30amp fuse keeps popping! BMWK100 Sprint Forum 7 06-23-2008 12:24 AM
Fuse Box HELP please BorgCymru Twins Technical Talk 11 12-14-2007 08:06 AM
Blown fuse - '05 955i MINI_Magic Daytona Deliberations 1 08-23-2005 03:48 AM
