'98 t595 60,000k service Q. - Triumph Forum: Triumph Rat Motorcycle Forums
Old 02-21-2010, 06:46 AM   #1 (permalink)
G'day all, i don't have a service/workshop manual and am 10klms from 60,000k's, wondered if anyone knows what work is done for this service. Thought it would be good to know what to expect before i get some quotes, thanks...
'98 955i / t595 Daytona
http://imagediary.aminus3.com
peterk is offline   Reply With Quote
Old 02-21-2010, 09:19 AM   #2 (permalink)
Favourite Bike: '04 D955i
bradtx's Avatar
Other Motorcycle: '98 T595
peterk, Main items added at every 20 K:
-valve check/adjustment
-headbearings adjust/lube
-air filter
-sparkplug renew
-balance TBs
-replace fuel filter
-fork oil replacement
Most important item is the valve check followed closely by the TB balance. Because the cam cover is removed, which requires sparkplug removal it's a good time to replace the sparkplugs.
Brad
Old 02-23-2010, 07:35 AM   #3 (permalink)
Thanks Brad, sounds like a bit of work! I am up for new chain and sprockets also, sounds like a quick $1,000, better start saving me thinks...
Old 02-23-2010, 07:59 AM   #4 (permalink)
bradtx's Avatar
peterk, Just to avoid any possible cylinder head damage, it's best to take it in for just the valve clearance/adjustment and new 'plugs, which should save around half. The others can be done when the wallet permits.
Brad
Old 02-26-2010, 07:42 AM   #5 (permalink)
Thanks Brad, sounds like a good idea! And trying not to show my lack of knowledge, i still gotta ask what r "-balance TBs"???
Old 02-26-2010, 08:50 AM   #6 (permalink)
bradtx's Avatar
peterk, That's balancing the throttle bodies. This procedure mainly effects the idle quality, but insures all cylinders are equally sharing the load throughout the rev range.
Brad
Old 03-01-2010, 09:40 PM   #7 (permalink)
OK thanks again!!!
T595 net Stampy Speed Triple Forum 6 12-14-2006 03:54 PM
T595 paulwillwin T3 Sport / Touring Forum 1 10-10-2006 07:07 PM
t595 endlessvend Daytona Deliberations 1 09-11-2006 09:15 AM
cost of 500 mile service and service plan xxxdog56 Sprint Forum 11 02-23-2005 02:18 AM
Service engine light after battery died. t595 Maintenance & Workshop Talk 11 09-10-2004 12:13 PM
