Since you have indicator lights (incl the neutral light) your alarm connector must be fine - the power circuit for ignition goes through the kill switch, then through the alarm before going on to power the ignition circuits - fact that kill is giving visual indication of the same effect that alarm interlock would have, says alarm interlock is indeed complete (good)
Originally Posted by jason ffoulkes
... I do have a separate light switch but no lights come on at all besides the dash lights! ....
Yes - but if you switch the headlights to 'on' position, do they come on?
If that answer is no, you have either a battery problem or a broken wire to ignition switch - most likely the former
Do you have a volt meter? Check the battery volts
Do you have any jumper cables? Hook it up via jumpers to a car battery and see what happens ..........
