2002 daytona CE fuel light on all the darn time - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearMotorcycle.comMotorcycle.com Classifieds!New Bonneville
Old 02-20-2010, 08:32 PM   #1 (permalink)
Favourite Bike: 1996 916
malott442's Avatar
Other Motorcycle: 2002 Triumph Daytona CE
Extra Motorcycle: 1998 Buell S1W
I just picked up a 2nd daytona.... yes! I have 2 Centennials sitting in my garage. I'm gonna get the new one ready, and sell old faithful when its time....
It has a few bugs. Tiny things. This one is the biggest pain.
Full tank of gas, troubleshot the sensor, and it is working fine. For the sake of speculation, I replaced it with the other sensor, and the light is still on.
It is on with the ignition like usual, and momentarily goes out when the bike fires, as normal. After less than 7 seconds of running, light is on..
Any suggestions?
I'm going outside right now to swap instrument clusters, and then I guess tomorrow I will be pulling the ECM to swap for a look.
Am I crazy, or is there an adjustment with Tuneboy? I don't have tuneboy yet. YET! I'm waiting to finish paying off tuition this semester, and after 4 years of cussing PCIII I think Im gonna TUNE the girl.
malott442 is offline   Reply With Quote
Old 02-20-2010, 08:43 PM   #2 (permalink)
DEcosse's Avatar
Do you have check engine light along with the low fuel light?
Go to Radio Shack & pick up a pack of resistors
http://www.radioshack.com/product/in...ductId=2062313
Disconnect the sensor and plug one resistor across the terminals of the harness connector - turn on ignition, wait 30 secs, light should be out.
Now take 2 resistors and twist them together so they are in series (for 94 ohms) - connect this combo across connector terminals - light should be on.
Try not to turn on ignition with nothing connected across the connector - that will generate an MIL light and it will take 3 hot/cool cycles to clear it (you may already have the MIL).
Since you have it common with both sensors, it may be a wiring issue.
Has the wiring to the instrument cluster been disturbed at all?
There are actually three black wires to the cluster - one is the ground, one is the oil pressure light & one is ground-interrupted by starter relay.
It almost sounds like the last one is mixed with the proper one given the change at starting (there is always delay on changing state with the fuel light, since it has a capacitive input)
Does your main beam indicator (or even oil pressure light) not work by chance?
Of course that would all suppose that the connector plug/harness to instruments had been repaired at some point
T'Rat.net BOTM November 2009
Old 02-20-2010, 10:07 PM   #3 (permalink)
malott442's Avatar
re:
The MIL light was not lit. I think I can swing by Radio shacky when I get up tomorrow..... I tried the sensor on my bike and it worked fine. I think you may be right about a ground being jacked up. The voltage signal to the tank is there. I think it was 5v or so. It was the same reading on both bikes.
I'll look at the grounds and see what I can uncover. I've already found one of the vacuum lines going from the ECU to the idle control circuit was MIA.
It ran fine somehow. ????
Last edited by malott442; 02-20-2010 at 10:08 PM. Reason: forgot to answer a question
Old 02-20-2010, 10:34 PM   #4 (permalink)
DEcosse's Avatar
Originally Posted by malott442 View Post
.... The voltage signal to the tank is there. I think it was 5v or so. It was the same reading on both bikes....
The voltage should be different depending on what the fuel level is - the resistance of the sender forms a voltage divider with a fixed resistor inside the ECM, so will be different for different fuel levels.
Unless you meant you measured it open circuit (connector un-plugged) of course ..........
Old 02-21-2010, 01:37 PM   #5 (permalink)
malott442's Avatar
Yes I measured them open.
Going to the shack now.
Old 02-21-2010, 02:24 PM   #6 (permalink)
malott442's Avatar
Back from the shack. 4 seconds to light going on after startup, invariably.
I guess it's time to look at the grounds I guess? I'm going to swap ECM's to just take a peek.... Both sets of fairings are off, both fuel tanks are unbolted.
The bike has been low-sided at a fairly low speed. The speedo doesn't work and the low fuel light is obviously on all the time. I haven't pulled the front wheel yet to check the sensor (lost my axle tool )
Is there a location for looking at the grounds? I don't see anywhere where the harness looks molested by the gauges, though a shadetree mechanic molested themself a more solid connection from the stator to the battery. No fuse, naturally.
Also, there is a plug by the battery with two loops on it. One has been cut and re-soldered. And I had to remove the harness from someone who previously installed a vapor (gauge for rpm and speed I guess?) on it. It was not on the bike anymore when I got my hands on it.
The oil pressure light appears to work. I'm going outside to check it right now.
Last edited by malott442; 02-21-2010 at 02:35 PM. Reason: forgot to answer other questions.
Old 02-21-2010, 02:45 PM   #7 (permalink)
malott442's Avatar
Swapped ECU's. Light works! Stranger than fiction........ Do you think maybe the ECU is internally jacked? Or would I be safe to try to get it re-set? Would a local stealership be able to fix it with tuning? I don't know anyone in the area with Tuneboy....
What year ECU's will work on it? 2002 Daytona CE
Old 02-21-2010, 02:49 PM   #8 (permalink)
malott442's Avatar
Additional information! Speedo now works as well!!!!!
Old 02-21-2010, 04:19 PM   #9 (permalink)
Favourite Bike: '04 D955i
bradtx's Avatar
Other Motorcycle: '98 T595
mallot442, Reinstall the suspect ECU in the new CE, or try it in the other CE. The ECUs are hard to hurt, except with a voltage spike. Possibly a loose connector?
The barometric pressure hose from the air box to the ECU can be disconnected with little or no degradation of performance. The air the ECU samples won't be filtered, however.
Brad
Old 02-21-2010, 04:26 PM   #10 (permalink)
DEcosse's Avatar
Did not realize speedo was not working - could have used that info earlier!
Know exactly what problem is now!
The loaded tune in that ECM is for 00-01 Daytona - that does not have the resistive fuel sender, electronic speedo sender - or the O2 sender
Get it re-flashed with the later tune & all will be well.
2002 Daytona engine management light saladin Daytona Deliberations 3 02-09-2010 09:50 AM
Are 2002 Sprint wheels and rotors interchangeable with 2002 Daytona 955i SSSA boo Daytona Deliberations 5 07-29-2008 04:35 PM
2002 S3 Low Fuel Light Teknic Speed Triple Forum 1 06-25-2006 09:04 PM
Low-Level Fuel Light--a different issue this time Impatient The Rocket Science Forum 8 07-24-2005 03:11 AM
Daytona 955i 2002 fuel tank removal Claude Maintenance & Workshop Talk 2 01-19-2005 08:44 AM
